Basical Libs
Library "std_logic_arith"
"integer which pointed"<=conv_integer(" unsigned_vector which pointed")
"vector which pointed"<=conv_std_logic_vectorr(" unsigned type,signed type or integer ","the bit_numbers")
also should you use the library named "std_logic_unsigned" for:
"integer which pointed"<=conv_integer(" std_logic_vector which pointed")
