请高人看看能否写出下面FPGA的结构:
# NB: The timing numbers in this architecture file have been modified # to comply with our NDA with the foundry providing us with process # information. The critical path delay output by VPR WILL NOT be accurate, # as we have intentionally altered the delays to introduce inaccuracy. # The numbers are still reasonable enough to allow CAD experimentation, # though. If you want real timing numbers, you'll have to insert your own # process data for the various, R, C, and Tdel entries.
# A simple architecture.
# All wires span only one logic block, and all routing switches are tri-state # buffers. # The logic block is a single 4-LUT + FF.
# Uniform channels. Each pin appears on only one side. io_rat 2 chan_width_io 1 chan_width_x uniform 1 chan_width_y uniform 1
# 4-input LUT. LUT inputs first, then output, then clock. inpin class: 0 bottom inpin class: 0 left inpin class: 0 top inpin class: 0 right outpin class: 1 bottom inpin class: 2 global top # Clock; shouldn't matter.
# Class 0 is LUT inputs, class 1 is the output, class 2 is the clock.
subblocks_per_clb 1 subblock_lut_size 4
#parameters needed only for detailed routing. #switch_block_type wilton #switch_block_type universal switch_block_type subset Fc_type fractional Fc_output 1 Fc_input 1 Fc_pad 1
segment frequency: 1 length: 1 wire_switch: 0 opin_switch: 0 Frac_cb: 1. \ Frac_sb: 1. Rmetal: 4.16 Cmetal: 81e-15
# Switch used as a tri-state buffer within the routing, and also as the # output buffer used to drive from a CLB output pin to a routing wire. switch 0 buffered: yes R: 786.9 Cin: 7.512e-15 Cout: 10.762e-15 \ Tdel: 456e-12
# Used only by the area model. R_minW_nmos 1967 R_minW_pmos 3738
# Timing info below.
C_ipin_cblock 7.512e-15 T_ipin_cblock 1.5e-9 T_ipad 478e-12 # clk_to_Q + 2:1 mux T_opad 295e-12 # Tsetup T_sblk_opin_to_sblk_ipin 0 # No local routing T_clb_ipin_to_sblk_ipin 0 # No local routing T_sblk_opin_to_clb_opin 0. # Delays through the BLE (LUT and a FF) T_subblock T_comb: 546e-12 T_seq_in: 845e-12 T_seq_out: 478e-12 ffice ffice" /> |
