最后提示的错误:
Build for Windows CE (Release) (Built on Apr 14 2005 13:54:39)
File names: Build.log Build.wrn Build.err Build.dat
CEBUILD: Running sysgen -p wceshellfe preproc
Starting sysgen phase for project ( wceshellfe )
Sysgening platform C:WINCE500platformsmdk2450
WINCE500build.err
C:WINCE500build.err
C:WINCE500build.log
C:WINCE500build.wrn
已复制 3 个文件.
BLDDEMO: There were errors building 2450_p900
2450_p900 - 3 error(s), 10 warning(s)
这个问题比较麻烦,我通过重装系统(换用另外一张堞装,非ghost),成功过一次,换用台式机,也成功过.但是笔记本上后来又不行了,原因不明.
四 B编译提示don't know how to make.........................
编译2450 bootloader出错,编译driver没错,
编译Eboot错误如下:
BUILD: [01:0000000039 ROGC ] Compiling .debug.c
BUILD: [01:0000000042 ROGC ] Compiling .ether.c
BUILD: [01:0000000045 ROGC ] Compiling .flash.c
BUILD: [01:0000000048 ROGC ] Compiling .nand.cpp
BUILD: [01:0000000051 ROGC ] Compiling .usb.c
BUILD: [01:0000000054 ROGC ] Assembling .usbs.s
BUILD: [00:0000000060 ROGC ] Linking WINCE500PLATFORMSMDK2450SrcBootloaderEboot.Whimory directory.
BUILD: [01:0000000067:ERRORE] NMAKE : U1073: don't know how to make 'E:WINCE500platformsmdk2450libarmV4Iretailoal_memory_s3c2450.lib'
BUILD: [01:0000000069:ERRORE] NMAKE.EXE -i -c BUILDMSG=Stop. LINKONLY=1 NOPASS0=1 failed - rc = 2
BUILD: [00:0000000070 ROGC ] Files Warnings Errors
BUILD: [00:0000000071 ROGC ] Midl 0 0 0
BUILD: [00:0000000072:PROGC ] Resource 0 0 0
BUILD: [00:0000000073:PROGC ] Message 0 0 0
BUILD: [00:0000000074:PROGC ] Precomp Header 0 0 0
BUILD: [00:0000000075:PROGC ] C/Cpp/Cxx 6 2 0
BUILD: [00:0000000076:PROGC ] Assembler 3 0 0
BUILD: [00:0000000077:PROGC ] Static Libraries 0 0 0
BUILD: [00:0000000078:PROGC ] Dll's 0 0 0
BUILD: [00:0000000079:PROGC ] Exe's 0 0 0
BUILD: [00:0000000080:PROGC ] Resx 0 0 0
BUILD: [00:0000000081:PROGC ] Csharp Targets 0 0 0
BUILD: [00:0000000082:PROGC ] Other 0 0 2
BUILD: [00:0000000083:PROGC ]
BUILD: [00:0000000084:PROGC ] Total 9 2 2
BUILD: [00:0000000085:PROGC ]
BUILD: [00:0000000086:PROGC ] 2 Warnings, 2 Errors
2450_p900 - 2 error(s), 2 warning(s)
我按照提示的路径找不着这个静态库,oal_memory_s3c2450.lib
难道这个静态库PB装时给漏掉了?
后来重装WINCE,打04,05,06,07年的补丁,问题依旧.看来还是没经验啊,感谢CSDN的高手Veabol,编译SrcCommon后,果真生成了oal_memory_s3c2450.lib.
可是又出来一个CS8900*.lib的静态库,后面的字符不记得了,看来还有其他地方要生成该库.编译整个SMDK2450工程,看提示估计是该静态库是生成了,但是又
弹出另外一个对话框,提示某文件无法编译,该文件为我已前做好的备份文件,有中文名.删除该文件后,再编译,仍然提示该错,将BSP根目录的build.dat删除,
再编译,问题彻底解决.
看来很多静态库不是PB装好后本身就有的,而需要编译一些代码才能生成. |
