struct uart_state *state;
int ret = 0;
state = drv->state + line;
if (mutex_lock_interruptible(&state->mutex)) {
ret = -ERESTARTSYS;
goto err;
state->count++;
if (!state->port || state->port->flags & UPF_DEAD) {
ret = -ENXIO;
goto err_unlock;
if (!state->info) {
state->info = kzalloc(sizeof(struct uart_info), GFP_KERNEL);
if (state->info) {
init_waitqueue_head(&state->info->open_wait);
init_waitqueue_head(&state->info->delta_msr_wait);
* Link the info into the other structures.
state->port->info = state->info;
tasklet_init(&state->info->tlet, uart_tasklet_action,
(unsigned long)state);
} else {
ret = -ENOMEM;
goto err_unlock;
return state;
err_unlock:
state->count--;
mutex_unlock(&state->mutex);
err:
return ERR_PTR(ret);
从代码中可以看出。这里注要是操作是初始化state->info.注意port->info就是state->info的一个副本。即port直接通过port->info可以找到它要操作的缓存区。
uart_startup()代码如下:
static int uart_startup(struct uart_state *state, int init_hw)
struct uart_info *info = state->info;
struct uart_port *port = state->port;
unsigned long page;
int retval = 0;
if (info->flags & UIF_INITIALIZED)
return 0;
* Set the TTY IO error marker - we will only clear this
* once we have successfully opened the port. Also set
* up the tty->alt_speed kludge
set_bit(TTY_IO_ERROR, &info->tty->flags);
if (port->type == PORT_UNKNOWN)
return 0;
* Initialise and allocate the transmit and temporary
* buffer.
if (!info->xmit.buf) {
page = get_zeroed_page(GFP_KERNEL);
if (!page)
return -ENOMEM;
info->xmit.buf = (unsigned char *) page;
uart_circ_clear(&info->xmit);
retval = port->ops->startup(port);
if (retval == 0) {
if (init_hw) {
* Initialise the hardware port settings.
uart_change_speed(state, NULL);
* Setup the RTS and DTR signals once the
* port is open and ready to respond.
if (info->tty->termios->c_cflag & CBAUD)
uart_set_mctrl(port, TIOCM_RTS | TIOCM_DTR);
if (info->flags & UIF_CTS_FLOW) {
spin_lock_irq(&port->lock);
if (!(port->ops->get_mctrl(port) & TIOCM_CTS))
info->tty->hw_stopped = 1;
spin_unlock_irq(&port->lock);
info->flags |= UIF_INITIALIZED;
clear_bit(TTY_IO_ERROR, &info->tty->flags);
if (retval && capable(CAP_SYS_ADMIN))
retval = 0;
return retval;
在这里,注要完成对环形缓冲,即info->xmit的初始化。然后调用port->ops->startup( )将这个port带入到工作状态。其它的是一个可调参数的设置,就不详细讲解了。
七:设备节点的write操作
Write操作对应的操作接口为uart_write( )。代码如下:
static int
uart_write(struct tty_struct *tty, const unsigned char *buf, int count)
struct uart_state *state = tty->driver_data;
struct uart_port *port;
struct circ_buf *circ;
unsigned long flags;
int c, ret = 0;
* This means you called this function _after_ the port was
* closed. No cookie for you.
if (!state || !state->info) {
WARN_ON(1);
return -EL3HLT;
port = state->port;
circ = &state->info->xmit;
if (!circ->buf)
return 0;
spin_lock_irqsave(&port->lock, flags);
while (1) {
c = CIRC_SPACE_TO_END(circ->head, circ->tail, UART_XMIT_SIZE);
if (count < c)
c = count;
if (c <= 0)
break;
memcpy(circ->buf + circ->head, buf, c);
circ->head = (circ->head + c) & (UART_XMIT_SIZE - 1);
buf += c;
count -= c;
ret += c;
spin_unlock_irqrestore(&port->lock, flags);
uart_start(tty);
return ret;
Uart_start()代码如下:
static void uart_start(struct tty_struct *tty)
__uart_start(tty);
static void __uart_start(struct tty_struct *tty)
if (!uart_circ_empty(&state->info->xmit) && state->info->xmit.buf &&
!tty->stopped && !tty->hw_stopped)
port->ops->start_tx(port);
显然,对于write操作而言,它就是将数据copy到环形缓存区。然后调用port->ops->start_tx()将数据写到硬件寄存器。
八:Read操作
Uart的read操作同Tty的read操作相同,即都是调用ldsic->read()读取read_buf中的内容。有对这部份内容不太清楚的,参阅《 linux设备模型之tty驱动架构》.
九:小结
本小节是分析serial驱动的基础。在理解了tty驱动架构之后,再来理解uart驱动架构应该不是很难。随着我们在linux设备驱动分析的深入,越来越深刻的体会到,linux的设备驱动架构很多都是相通的。只要深刻理解了一种驱动架构。举一反三。也就很容易分析出其它架构的驱动了。 |
