vxWorks提供了一个用户接口usrAppInit。我们可以根据需求来实现或者改写这个函数,对应的usrAppInit.c在已创建的VIP目录下。VIP编译的过程中这个函数将被编译进内核镜像,在系统启动后将会自动执行这个函数。
函数原始定义如下:
/* usrAppInit.c - stub application initialization routine */
/* Copyright (c) 1998,2006 Wind River Systems, Inc.
* The right to copy, distribute, modify or otherwise make use
* of this software may be licensed only pursuant to the terms
* of an applicable Wind River license agreement.
modification history
01b,16mar06,jmt Add header file to find USER_APPL_INIT define
01a,02jun98,ms written
DESCRIPTION
Initialize user application code.
#include <vxWorks.h>
#if defined(PRJ_BUILD)
#include "prjParams.h"
#endif /* defined PRJ_BUILD */
* usrAppInit - initialize the users application
void usrAppInit (void)
#ifdef USER_APPL_INIT
USER_APPL_INIT; /* for backwards compatibility */
#endif
/* add application specific code here */
