S3C2410的WINCE BSP添加串口支持 02
然后修改下这个地方:
MapIrq2SysIntr(DWORD _Irq)
if( _Irq<=19 )
return ( SYSINTR_FIRMWARE + _Irq );
else
return (0xffffffff);
3、打开串口源文件中ser2410_hw.c文件。
搜索:
S2410_SetSerialIOP(
PVOID pHead // @parm points to device head
将其函数改为:
PS2410_UART_INFO pHWHead = (PS2410_UART_INFO)pHead;
PSER_INFO pHWHead1 = (PSER_INFO)pHead;
RETAILMSG(DEBUGMODE, (TEXT("S2410_SetSerialIOP ")));
if(pHWHead1->dwIOBase == 0x50004000)
#if USEVIRTUAL
EnterCriticalSection(&(pHWHead->RegCritSec));
v_pIOPregs->rGPHCON &= ~(0x3<<8 | 0x3<<10 /*| 0x3<<12 | 0x3<<14*/); // clear uart 1 - rx, tx
v_pIOPregs->rGPHCON |= (0x2<<8 | 0x2<<10 /*| 0x1<<12 | 0x0<<14*/);
v_pIOPregs->rGPHCON |= (0x2<<0 | 0x2<<2 );
v_pIOPregs->rGPHUP |= 0x03;
pHWHead->rDTRport = (volatile unsigned int *)&(v_pIOPregs->rGPHDAT);
pHWHead->rDSRport = (volatile unsigned int *)&(v_pIOPregs->rGPHDAT);
pHWHead->DtrPortNum = 0;
pHWHead->DsrPortNum = 1;
#else
volatile IOPreg *s2410IOP;
s2410IOP = (volatile IOPreg *)IOP_BASE;
s2410IOP->rGPHCON &= ~(0x3<<8 | 0x3<<10/* | 0x3<<12 | 0x3<<14*/); // clear uart 1 - rx, tx
s2410IOP->rGPHCON |= (0x2<<8 | 0x2<<10 /*| 0x1<<12 | 0x0<<14*/);
s2410IOP->rGPHCON |= (0x2<<0 | 0x2<<2 );
s2410IOP->rGPHUP |= 0x03;
pHWHead->rDTRport = (volatile unsigned int *)(IOP_BASE+0x74); //s2410IOP->rGPHDAT
pHWHead->rDSRport = (volatile unsigned int *)(IOP_BASE+0x74);
#endif
else if(pHWHead1->dwIOBase == 0x50008000)
#if USEVIRTUAL
v_pIOPregs->rGPHCON &= ~( 0x3<<12 | 0x3<<14); // clear uart 2 - rx, tx
v_pIOPregs->rGPHCON |= ( 0x2<<12 | 0x2<<14);
v_pIOPregs->rGPHUP &= ~0xc0;
#else
s2410IOP->rGPHCON &= ~(0x3<<12 | 0x3<<14); // clear uart 2 - rx, tx
s2410IOP->rGPHCON |= ( 0x02<<12 | 0x02<<14);
s2410IOP->rGPHUP &= ~0xc0;
#endif
else
#if USEVIRTUAL
v_pIOPregs->rGPHCON &= ~(0x3<<0 | 0x3<<2 | 0x3<<4 | 0x3<<6/* | 0x3<<12 | 0x3<<14*/); // clear uart 0 - rx, tx
v_pIOPregs->rGPHCON |= (0x2<<4 | 0x2<<6/* | 0x1<<12 | 0x0<<14*/);
#else
s2410IOP->rGPHCON &= ~(0x3<<0 | 0x3<<2 | 0x3<<4 | 0x3<<6 /*| 0x3<<12 | 0x3<<14*/); // clear uart 0 - rx, tx
s2410IOP->rGPHCON |= (0x2<<4 | 0x2<<6 /*| 0x1<<12 | 0x0<<14*/);
pHWHead->DsrPortNum =1;
#endif
LeaveCriticalSection(&(pHWHead->RegCritSec));
接着搜索:
SL_Init(
PVOID pHead, // @parm points to device head
PUCHAR pRegBase, // Pointer to 16550 register base
UINT8 RegStride, // Stride amongst the 16550 registers
EVENT_FUNC EventCallback, // This callback exists in MDD
PVOID pMddHead, // This is the first parm to callback
PLOOKUP_TBL pBaudTable // BaudRate Table
在PS2410_UART_INFO pHWHead = (PS2410_UART_INFO)pHead;这一句后面添加:
PSER_INFO pHWHead1 = (PSER_INFO)pHead; |
