NEC单片机 UPD78F9234 16位定时器使用例程(汇编)
Lable def
LED8_MODE    EQU        PM2.1
LED7_MODE    EQU        PM2.0
LED6_MODE    EQU        PM12.0
LED5_MODE    EQU        PM0.3
LED4_MODE    EQU        PM0.2
LED3_MODE    EQU        PM0.1
LED2_MODE    EQU        PM0.0
LED1_MODE    EQU        PM12.3
LED8    EQU        P2.1
LED7    EQU        P2.0
LED6    EQU        P12.0
LED5    EQU     P0.3
LED4    EQU        P0.2
LED3    EQU        P0.1
LED2    EQU        P0.0
LED1    EQU        P12.3
;=========================(debug  resource)======================================={
; VAR DEF
DATA_SEGMENT1  DSEG  SADDR      ;  (AT 0FE20H)
VAR_1:   DS  1
ORG 018H
DB 0FFH,0FFH;
ORG 07EH
DB 0FFH,0FFH;
ORG 81H
DB 0FFH;
ORG    01ED0H
DB 0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
;INTERRUPT VECT
ORG 0000H
DW   START_PROGRAM
ORG 000EH
DW   INTTM000_VECT
;CODE
     CSEG   ;(AT  XXXXH)
START_PROGRAM:
DI
MOVW AX,#0FE20H;
MOVW SP,AX;
MOV PCC,#00H;
MOV PPCC,#00H;
CALL  !DELAY_1MS;
CALL  !DELAY_1MS;
CALL  !DELAY_1MS;
CALL  !DELAY_1MS;
CALL  !DELAY_1MS;
MOV PMC2,#00H
MOV PM2,#0FFH
; SET TM00
MOV TMC00,#00H
MOV PRM00,#02H    ;31.25KHz    32us
MOVW AX,#31250;9800    ;313.6ms    15625
MOVW CR000,AX
CLR1 TMIF000    ;clear sign
CLR1 TMMK000    ;allow interrupt
MOV TMC00,#0CH    ;clear the CR000 when TM00=CR000
EI
CLR1  LED1_MODE
CLR1  LED2_MODE
CLR1  LED3_MODE
CLR1  LED4_MODE
CLR1  LED5_MODE
CLR1  LED6_MODE
CLR1  LED7_MODE
CLR1  LED8_MODE
SET1    LED1
SET1    LED2
SET1    LED3
SET1    LED4
SET1    LED5
SET1    LED6
SET1    LED7
SET1    LED8
CLR1  LED1
MAIN:
MOV WDTE,#0ACH;
BR   !MAIN
; SUB PROGRAM
CSEG
DELAY_1MS:
     MOV  B,#0FFH
BBBB:
     DBNZ B,$BBBB;
RET
;INTERRUPT FUNCTION
CSEG
INTTM000_VECT:
BT   LED1,$LED22    ;jump if LED1=1
SET1    LED1
CLR1    LED2
BR        !backtrack
LED22:
BT    LED2,$LED33
SET1    LED2
CLR1    LED3
BR        !backtrack
LED33:
BT    LED3,$LED44
SET1    LED3
CLR1    LED4
BR        !backtrack
LED44:
BT    LED4,$LED55
SET1    LED4
CLR1    LED5
BR        !backtrack
LED55:
BT    LED5,$LED66
SET1    LED5
CLR1    LED6
BR        !backtrack
LED66:
BT    LED6,$LED77
SET1    LED6
CLR1    LED7
BR        !backtrack
LED77:
BT    LED7,$LED88
SET1    LED7
CLR1    LED8
BR        !backtrack
LED88:
BT    LED8,$INTTM000_VECT
SET1    LED8
CLR1    LED1
BR        !backtrack
backtrack:
RETI
END
UPD78F9234产品参数:
MCU 8BIT 8KB FLASH 30PIN
核心处理器:78K0S
芯体尺寸:8-位
速度:10MHz
连通性:LIN,UART/USART
外围设备:LVD, POR, PWM, WDT
输入/输出数:24
程序存储器容量:8KB (8K x 8)
程序存储器类型:FLASH
EEPROM 大小:-
RAM 容量:256 x 8
电压 - 电源 (Vcc/Vdd):2 V ~ 5.5 V
数据转换器:A/D 4x10b
振荡器型:内部
工作温度:-40°C ~ 85°C
