ADI ADSP-BF527 EZ-KIT Lite评估开发方案
关键词: ADI , ADSP-BF527 , EZ-KIT , Lite
ADI公司的ADSP-BF52x是600MHz高性能Blackfin处理器,采用ADI/Intel的微信号架构(MSA),包括了双MAC的信号处理引擎,RISC类微处理器指令以及SIMD多媒体功能.而ADSP-BF527 EZ-KIT Lite评估板通过基于USB PC主机的高性价比评估 DSP-BF527的平台.本文介绍了ADSP-BF52x主要特性,方框图,ADSP-BF527 EZ-KIT Lite评估板主要特性,系统框图,电路图,材料清单和PCB布局图.
The ADSP-BF52x processors are members of the Blackfin family of products, incorporating the Analog Devices/Intel Micro Signal Architecture (MSA). Blackfin® processors combine a dual-MAC state-of-the-art signal processing engine, the advantages of a clean, orthogonal RISC-like microprocessor instruction set, and single-instruction, multiple-data (SIMD) multimedia capabilities into a single instruction-set architecture.
The ADSP-BF52x processors are completely code compatible with other Blackfin processors. The ADSP-BF523/ ADSP-BF525/ADSP-BF527 processors offer performance up to 600 MHz. The ADSP-BF522/ADSP-BF524/ADSP-BF526 processors offer performance up to 400 MHz and reduced static power consumption.
ADSP-BF52x主要特性:
Up to 600MHz high performance Blackfin processor
Two 16-bit MACs, two 40-bit ALUs, four 8-bit video ALUs, 40-bit shifter
RISC-like register and instruction model for ease of programming and compiler-friendly support
Advanced debug, trace, and performance monitoring
Accepts a wide range of supply voltages for internal and I/O operations.
Programmable on-chip voltage regulator (ADSP-BF523/ADSP-BF525/ADSP-BF527 processors only)
Qualified for Automotive Applications.
289-ball and 208-ball CSP_BGA packages
MEMORY
132K bytes of on-chip memory (See Table 1 on Page 3 for L1 and L3 memory size details) External memory controller with glueless support for SDRAM and asynchronous 8-bit and 16-bit memories
Flexible booting options from external flash, SPI, and TWI memory or from host devices including SPI, TWI, and UART
Code security with Lockbox Secure Technology
one-time-programmable (OTP) memory
Memory management unit providing memory protection
PERIPHERALS
USB 2.0 high speed on-the-go (OTG) with integrated PHY
IEEE 802.3-compliant 10/100 Ethernet MAC
Parallel peripheral interface (PPI), supporting ITU-R 656 video data formats
Host DMA port (HOSTDP)
2 dual-channel, full-duplex synchronous serial ports (SPORTs), supporting eight stereo I2S channels
12 peripheral DMAs, 2 mastered by the Ethernet MAC
2 memory-to-memory DMAs with external request lines
Event handler with 54 interrupt inputs
Serial peripheral interface (SPI) compatible port
2 UARTs with IrDA support
2-wire interface (TWI) controller
Eight 32-bit timers/counters with PWM support
32-bit up/down counter with rotary support
Real-time clock (RTC) and watchdog timer
32-bit core timer
48 general-purpose I/Os (GPIOs), with programmable hysteresis
NAND flash controller (NFC)
Debug/JTAG interface
On-chip PLL capable of frequency multiplication
图1.ADSP-BF52x处理器框图
Thank you for purchasing the ADSP-BF527 EZ-KIT Lite®, Analog Devices, Inc. evaluation system for the ADSP-BF523, ADSP-BF525, and ADSP-BF527 Blackfin® processors.Blackfin processors embody a new type of embedded processor designed specifically to meet the computational demands and power constraints of today’s embedded audio, video, and communications applications. They deliver breakthrough signal-processing performance and power efficiency within a reduced instruction set computing (RISC) programming model.
Blackfin processors support a media instruction set computing (MISC) architecture. This architecture is the natural merging of RISC, media functions, and digital signal processing (DSP) characteristics. Blackfin processors deliver signal-processing performance in a microprocessor-like environment.
Based on the Micro Signal Architecture (MSA), Blackfin processors combine a 32-bit RISC instruction set, dual 16-bit multiply accumulate (MAC) DSP functionality, and eight-bit video processing performance that had previously been the exclusive domain of very-long instruction word (VLIW) media processors.
The evaluation board is designed to be used in conjunction with the VisualDSP++® development environment to test capabilities of the
ADSP-BF523/BF525/BF527 Blackfin processors. The VisualDSP++development environment aids advanced application code development and debug, such as:
• Create, compile, assemble, and link application programs written in C++, C, and ADSP-BF527 assembly
• Load, run, step, halt, and set breakpoints in application programs
• Read and write data and program memory
• Read and write core and peripheral registers
• Plot memory
Access to the processor from a personal computer (PC) is achieved through a USB port or an external JTAG emulator. The USB interface provides unrestricted access to the ADSP-BF527 processor and evaluation board peripherals. Analog Devices JTAG emulators offer faster communication between the host PC and target hardware. Analog Devices carries a wide range of in-circuit emulation products.
The ADSP-BF527 EZ-KIT Lite provides example programs to demonstrate the evaluation board capabilities.
ADSP-BF527 EZ-KIT Lite评估板主要特性:
• Analog Devices ADSP-BF527 Blackfin processor
• Core performance up to 600 MHz
• External bus performance up to 133 MHz
• 289-pin 0.5 mm pitch mini-BGA package
• 25 MHz oscillator
• Synchronous dynamic random access memory (SDRAM)
• Micron MT48LC32M16A2TG – 64 MB (8M x 16 bits x 4 banks)
• Parallel flash memory
• ST Micro M29W320EB – 32 Mb (2M x 16 bits)
• NAND flash memory
• Numonyx NAND04 – 4 Gb
• SPI flash memory
• ST Micro M25P16 – 16 Mb
• Internal audio codec
• Low-power audio codec
• One stereo LINE OUT jack
• One input MIC jack
• One input stereo LINE IN jack
• TFT LCD display with touchscreen
• Sharp LQ035Q1DH02 320 x 240 3.5’’ touchscreen LCD
• Analog Devices AD7879-1 four-wire touchscreen controller
• Ethernet interface
• SMSC LAN8700 PHY device
• 10-BaseT and 100-BaseTX Ethernet controller
• Auto-MDIX
• Keypad
• Analog Devices ADP5520 keypad controller
• ACT components– 4 x 4 keypad assembly
• Thumbwheel
• CTS Corp rotary encoder
• Universal asynchronous receiver/transmitter (UART)
• ADM3202 RS-232 line driver/receiver
• DB9 female connector
LEDs
• Ten LEDs: one power (green), one board reset (red), three general-purpose (yellow), one USB monitor (amber), PHY link (yellow), PHY activity (green), keypad controller (red), and FPGA done (yellow)
• Push buttons
• Three push buttons: one reset, two programmable flags with debounce logic
• Expansion interface
• Provides access to all ADSP-BF527 processor signals
• Other features
• JTAG ICE 14-pin header
• USB OTG connector
• HOST interface connector
• Power measurement jumpers
• PPI IDC connector
• SPORT0 and SPORT1 IDC connectors
• TWI, SPI, timers, and UART0 IDC connectors
The ADSP-BF527 EZ-KIT Lite® provides developers with a cost-effective method for initial evaluation of the ADSP-BF527 Blackfin® Processors via a USB-based, PC-hosted tool set. With this EZ-KIT Lite, users can learn more about the Analog Devices (ADI) ADSP-BF527 hardware and software development, and quickly prototype a wide range of applications.
Blackfin Processor desktop evaluation board along with an evaluation suite of the VisualDSP++® development and debugging environment, including the C/C++ compiler, assembler, and linker. The evaluation suite of VisualDSP++ is designed to be used with the EZ-KIT Lite only.
The EZ-KIT Lite ships with with a landscape, Low Power QVGA Touch Screen LCD panel, a set of Stereo Headphones and all of the necessary supplemental cables (USB, Ethernet, etc.).
图2.ADSP-BF527 EZ-KIT Lite评估板外形图
ADSP-BF527 Processor: 289 Ball mBGA, 600MHz; LFBGA-SS2, 12mmX12mm/0.5 pitch, 4L, (A02)
SDRAM: 64 MB, 32M x 16; Micron MT48LC32M16A2 3.3V
FLASH: 4 MB (2M x 16 ); Numonyx M29W320EB70ZE6E 3.3V
NAND FLASH: 4 Gb Numonyx NAND04; NAND04GW3B2B 3.3V
SPI FLASH: 16 Mb Numonyx M25P16-VMW6G 3.3V
Thumbwheel: CTS Corp, Rotary Encoder, 2 Bit Binary, CT2999-ND
Keypad: ACT-07-30008-000-R
UART: ADM3202 RS-232 line driver/receiver; DB9 female connector
RTC Battery: 3.0 Volt Li-ION
LCD Display: Varitronix - Landscape QVGA, 5 in, 320x240, Touch Screen
Selectable Boot Mode
Audio I/O: Mic in, Line In, Headphone Out, Line Out
图3.ADSP-BF527 EZ-KIT Lite评估板系统框图
图4.ADSP-BF527 EZ-KIT Lite评估板电路图(1)
图5.ADSP-BF527 EZ-KIT Lite评估板电路图(2)
图6.ADSP-BF527 EZ-KIT Lite评估板电路图(3)
图7.ADSP-BF527 EZ-KIT Lite评估板电路图(4)
图8.ADSP-BF527 EZ-KIT Lite评估板电路图(5)
图9.ADSP-BF527 EZ-KIT Lite评估板电路图(6)
图10.ADSP-BF527 EZ-KIT Lite评估板电路图(7)
图11.ADSP-BF527 EZ-KIT Lite评估板电路图(8)
图12.ADSP-BF527 EZ-KIT Lite评估板电路图(9)
图13.ADSP-BF527 EZ-KIT Lite评估板电路图(10)
图14.ADSP-BF527 EZ-KIT Lite评估板电路图(11)
图15.ADSP-BF527 EZ-KIT Lite评估板电路图(12)
图16.ADSP-BF527 EZ-KIT Lite评估板电路图(13)
图17.ADSP-BF527 EZ-KIT Lite评估板电路图(14)
ADSP-BF527 EZ-KIT Lite评估板材料清单:
图18.ADSP-BF527 EZ-KIT Lite评估板PCB布局图:顶层
图19.ADSP-BF527 EZ-KIT Lite评估板PCB布局图:底层
详情请见:
ADSP-BF522_BF523_BF524_BF525_BF526_BF527.pdf (2.92 MB, 下载次数: 0) 2012-5-28 14:27:23 上传
下载次数: 0
下载积分: 积分 -1
BF527_EZKIT_Lite_manual_Rev_1.6.pdf (1.12 MB, 下载次数: 0)
