求助:CCS3.1 F2812的simulator 时,出错
请问,我用CCS3.1 F2812的simulator 时,错现如下问题:   DevEmuRegs.M0RAMDFT = 0x0300;   DevEmuRegs.M1RAMDFT = 0x0300;   DevEmuRegs.L0RAMDFT = 0x0300;   DevEmuRegs.L1RAMDFT = 0x0300;   DevEmuRegs.H0RAMDFT = 0x0300; 当运行到上面几句时,提示如下错问:Can't Run Target CPU: Can't write to data memory 0x950, check memory config [-2184] Can't Run Target CPU: Can't write to data memory 0x951, check memory config [-2184] Can't Run Target CPU: Can't write to data memory 0x952, check memory config [-2184] Can't Run Target CPU: Can't write to data memory 0x953, check memory config [-2184] Can't Run Target CPU: Can't write to data memory 0x954, check memory config [-2184]cmd文件中MEMORY{PAGE 1 :    /*&nbsperipheral Frame 0:   */   DEV_EMU    : origin = 0x000880, length = 0x000180}SECTIONS{      DevEmuRegsFile    : &gt DEV_EMU,   &nbspAGE = 1}请问这是什么原因啊
