RTC实时时钟驱动(5)
RTC实时时钟驱动(5)
pr_debug("s3c2410_rtc: tick irq %d, alarm irq %d\n",
         s3c_rtc_tickno, s3c_rtc_alarmno);
    /* get the memory region */
    res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
    if (res == NULL) {
        dev_err(&pdev->dev, "failed to get memory region resource\n");
        return -ENOENT;
    s3c_rtc_mem = request_mem_region(res->start,
                     res->end-res->start+1,
                     pdev->name);
    if (s3c_rtc_mem == NULL) {
        dev_err(&pdev->dev, "failed to reserve memory region\n");
        ret = -ENOENT;
        goto err_nores;
    s3c_rtc_base = ioremap(res->start, res->end - res->start + 1);
    if (s3c_rtc_base == NULL) {
        dev_err(&pdev->dev, "failed ioremap()\n");
        ret = -EINVAL;
        goto err_nomap;
    /* check to see if everything is setup correctly */
    s3c_rtc_enable(pdev, 1);
     pr_debug("s3c2410_rtc: RTCCON=%02x\n",
         readb(s3c_rtc_base + S3C2410_RTCCON));
    s3c_rtc_setfreq(&pdev->dev, 1);
    device_init_wakeup(&pdev->dev, 1);
    /* register RTC and exit */
    rtc = rtc_device_register("s3c", &pdev->dev, &s3c_rtcops,
                  THIS_MODULE);
    if (IS_ERR(rtc)) {
        dev_err(&pdev->dev, "cannot attach rtc\n");
        ret = PTR_ERR(rtc);
        goto err_nortc;
    rtc->max_user_freq = 128;
    platform_set_drvdata(pdev, rtc);
    return 0;
err_nortc:
    s3c_rtc_enable(pdev, 0);
    iounmap(s3c_rtc_base);
err_nomap:
    release_resource(s3c_rtc_mem);
err_nores:
    return ret;
继承事业,薪火相传
