打开vivado软件报错$vivado &****** Vivado v2012.1 (64-bit) **** Build 179419 by xbuild on Thu Apr 26 11:38:48 MDT 2012 ** Copyright 1986-1999, 2001-2012 Xilinx, Inc. All Rights Reserved.INFO: [Vivado-1] No Vivado early access license found. Contact your local Xilinx Field Application Engineer for more license information.INFO: [Device-36] Loading parts and site information from /Xilinx_software/Xilinx14.1/14.1/ISE_DS/PlanAhead/data/parts/arch.xmlParsing RTL primitives file [/Xilinx_software/Xilinx14.1/14.1/ISE_DS/PlanAhead/data/parts/xilinx/rtl/prims/rtl_prims.xml]Finished parsing RTL primitives file [/Xilinx_software/Xilinx14.1/14.1/ISE_DS/PlanAhead/data/parts/xilinx/rtl/prims/rtl_prims.xml]start_guistarting gui ...java.lang.reflect.InvocationTargetException at java.awt.EventQueue.invokeAndWait(EventQueue.java:1242) at javax.swing.SwingUtilities.invokeAndWait(SwingUtilities.java:1346) at ui.PlanAhead.aKg(SourceFile:338) at ui.PlanAhead.aKh(SourceFile:492) at ui.PlanAhead.a(SourceFile:1033) at ui.frmwork.U.f(SourceFile:35) at ui.frmwork.HTclEventBroker.a(SourceFile:223) at ui.frmwork.HTclEventBroker.fireTclEvent(SourceFile:311)Caused by: java.lang.ExceptionInInitializerError at ui.bp.run(SourceFile:343) at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:241) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:705) at java.awt.EventQueue.access$000(EventQueue.java:101) at java.awt.EventQueue$3.run(EventQueue.java:666) at java.awt.EventQueue$3.run(EventQueue.java:664) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:675) at ui.frmwork.v.dispatchEvent(SourceFile:73) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:211) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:128) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:117) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:113) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:105) at java.awt.EventDispatchThread.run(EventDispatchThread.java:90)Caused by: java.lang.NullPointerException at javax.swing.ImageIcon.<init>(ImageIcon.java:228) at com.jidesoft.icons.IconsFactory.i(SourceFile:570) at com.jidesoft.icons.IconsFactory.h(SourceFile:548) at com.jidesoft.icons.IconsFactory.d(SourceFile:176) at ui.d.d.<clinit>(SourceFile:1107) ... 16 morejava.lang.reflect.InvocationTargetException at java.awt.EventQueue.invokeAndWait(EventQueue.java:1242) at javax.swing.SwingUtilities.invokeAndWait(SwingUtilities.java:1346) at ui.PlanAhead.g(SourceFile:934) at ui.PlanAhead.aKg(SourceFile:400) at ui.PlanAhead.aKh(SourceFile:492) at ui.PlanAhead.a(SourceFile:1033) at ui.frmwork.U.f(SourceFile:35) at ui.frmwork.HTclEventBroker.a(SourceFile:223) at ui.frmwork.HTclEventBroker.fireTclEvent(SourceFile:311)Caused by: java.lang.NoClassDefFoundError: Could not initialize class ui.d.d at ui.views.F.f.<clinit>(SourceFile:22) at ui.av.<init>(SourceFile:152) at ui.by.run(SourceFile:841) at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:241) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:705) at java.awt.EventQueue.access$000(EventQueue.java:101) at java.awt.EventQueue$3.run(EventQueue.java:666) at java.awt.EventQueue$3.run(EventQueue.java:664) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:675) at ui.frmwork.v.dispatchEvent(SourceFile:73) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:211) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:128) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:117) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:113) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:105) at java.awt.EventDispatchThread.run(EventDispatchThread.java:90) |
