一步步写STM32 PendSV与堆栈操作(4)
main.c内容如下:
[url=][/url]
#include "stdio.h"#define OS_EXCEPT_STK_SIZE 1024#define TASK_1_STK_SIZE 1024#define TASK_2_STK_SIZE 1024typedef unsigned int OS_STK;typedef void (*OS_TASK)(void);typedef struct OS_TCB{  OS_STK *StkAddr;}OS_TCB,*OS_TCBP;OS_TCBP g_OS_Tcb_CurP; OS_TCBP g_OS_Tcb_HighRdyP;static OS_STK OS_CPU_ExceptStk[OS_EXCEPT_STK_SIZE];OS_STK *g_OS_CPU_ExceptStkBase;static OS_TCB TCB_1;static OS_TCB TCB_2;static OS_STK TASK_1_STK[TASK_1_STK_SIZE];static OS_STK TASK_2_STK[TASK_2_STK_SIZE];extern void OSStart_Asm(void);extern void OSCtxSw(void);void Task_Switch(){  if(g_OS_Tcb_CurP == &TCB_1)    g_OS_Tcb_HighRdyP=&TCB_2;  else    g_OS_Tcb_HighRdyP=&TCB_1;   OSCtxSw();}void task_1(){  printf("Task 1 Running!!!\n");  Task_Switch();  printf("Task 1 Running!!!\n");  Task_Switch();}void task_2(){    printf("Task 2 Running!!!\n");  Task_Switch();  printf("Task 2 Running!!!\n");  Task_Switch();}void Task_End(void){  printf("Task End\n");  while(1)  {}}void Task_Create(OS_TCB *tcb,OS_TASK task,OS_STK *stk){    OS_STK  *p_stk;    p_stk      = stk;    p_stk      = (OS_STK *)((OS_STK)(p_stk) & 0xFFFFFFF8u);        *(--p_stk) = (OS_STK)0x01000000uL;                          //xPSR    *(--p_stk) = (OS_STK)task;                                  // Entry Point    *(--p_stk) = (OS_STK)Task_End;                                     // R14 (LR)    *(--p_stk) = (OS_STK)0x12121212uL;                          // R12    *(--p_stk) = (OS_STK)0x03030303uL;                          // R3    *(--p_stk) = (OS_STK)0x02020202uL;                          // R2    *(--p_stk) = (OS_STK)0x01010101uL;                          // R1    *(--p_stk) = (OS_STK)0x00000000u;                           // R0        *(--p_stk) = (OS_STK)0x11111111uL;                          // R11    *(--p_stk) = (OS_STK)0x10101010uL;                          // R10    *(--p_stk) = (OS_STK)0x09090909uL;                          // R9    *(--p_stk) = (OS_STK)0x08080808uL;                          // R8    *(--p_stk) = (OS_STK)0x07070707uL;                          // R7    *(--p_stk) = (OS_STK)0x06060606uL;                          // R6    *(--p_stk) = (OS_STK)0x05050505uL;                          // R5    *(--p_stk) = (OS_STK)0x04040404uL;                          // R4        tcb->StkAddr=p_stk;}int main(){    g_OS_CPU_ExceptStkBase = OS_CPU_ExceptStk + OS_EXCEPT_STK_SIZE - 1;    Task_Create(&TCB_1,task_1,&TASK_1_STK[TASK_1_STK_SIZE-1]);  Task_Create(&TCB_2,task_2,&TASK_2_STK[TASK_1_STK_SIZE-1]);      g_OS_Tcb_HighRdyP=&TCB_1;    OSStart_Asm();    return 0;}
继承事业,薪火相传
