Embest Atmel AT91SAM3U ARM-CM3 MCU开发方案(3)
• I/O
– Up to 96 I/O lines with external interrupt capability (edge or level sensitivity), debouncing, glitch filtering and on-die Series Resistor Termination
– Three 32-bit Parallel Input/Outputs (PIO)
• Packages
– 100-lead LQFP, 14 x 14 mm, pitch 0.5 mm
– 100-ball LFBGA, 9 x 9 mm, pitch 0.8 mm
144-lead LQFP, 20 x 20 mm, pitch 0.5 mm
– 144-ball LFBGA, 10 x 10 mm, pitch 0.8 mm
图1.100引脚AT91SAM3U 方框图
图2.144引脚AT91SAM3U 方框图
ATSAM3U ARM-CM3开发板
The ATSAM3U ARM-CM3 Board is an ARM embedded evaluation board produced by Embest, integrate the ATMEL Cortex-M3 core-based processor ATSAM3U4E, operating at 96 MHz frequency. The board features USB, I2C, MCI interface, TFT-LCD, USART interface, 96 I/O port, EBI support SRAM/NOR/NAND memory, etc. Plenty of software examples, which can be used in Keil MDK environment, are accompanied in CDROM. You can use the Cortex-M3 based AT91SAM3U Evaluation Board to generate and test application programs for the ATMEL SAM3U Series microcontroller family. With this hands-on process, you can determine the hardware and software requirements for current and future product development.
The AT91SAM3U Evaluation Board ships with the AT91SAM3U device that is a superset of several other device variants of the ATMEL SAM3U microcontroller series. The AT91SAM3U Board contains all the hardware components required in a single-chip AT91SAM3U4E system.
图3.ATSAM3U ARM-CM3开发板外形图 |
