ucos代码裁剪(2)
ucos代码裁剪(2)
  •                                        /* --------------------- MEMORY MANAGEMENT -------------------- */
  • #define OS_MEM_EN                 1    /* Enable (1) or Disable (0) code generation for MEMORY MANAGER */
  • #define OS_MEM_QUERY_EN           1    /*     Include code for OSMemQuery()                            */
  •                                        /* ---------------- MUTUAL EXCLUSION SEMAPHORES --------------- */
  • #define OS_MUTEX_EN               1    /* Enable (1) or Disable (0) code generation for MUTEX          */
  • #define OS_MUTEX_ACCEPT_EN        1    /*     Include code for OSMutexAccept()                         */
  • #define OS_MUTEX_DEL_EN           1    /*     Include code for OSMutexDel()                            */
  • #define OS_MUTEX_QUERY_EN         1    /*     Include code for OSMutexQuery()                          */
  •                                        /* ---------------------- MESSAGE QUEUES ---------------------- */
  • #define OS_Q_EN                   1    /* Enable (1) or Disable (0) code generation for QUEUES         */
  • #define OS_Q_ACCEPT_EN            1    /*     Include code for OSQAccept()                             */
  • #define OS_Q_DEL_EN               1    /*     Include code for OSQDel()                                */
  • #define OS_Q_FLUSH_EN             1    /*     Include code for OSQFlush()                              */
  • #define OS_Q_POST_EN              1    /*     Include code for OSQPost()                               */
  • #define OS_Q_POST_FRONT_EN        1    /*     Include code for OSQPostFront()                          */
  • #define OS_Q_POST_OPT_EN          1    /*     Include code for OSQPostOpt()                            */
  • #define OS_Q_QUERY_EN             1    /*     Include code for OSQQuery()                              */
  •                                        /* ------------------------ SEMAPHORES ------------------------ */
  • #define OS_SEM_EN                 1    /* Enable (1) or Disable (0) code generation for SEMAPHORES     */
  • #define OS_SEM_ACCEPT_EN          1    /*    Include code for OSSemAccept()                            */
  • #define OS_SEM_DEL_EN             1    /*    Include code for OSSemDel()                               */
  • #define OS_SEM_QUERY_EN           1    /*    Include code for OSSemQuery()                             */
  •                                        /* --------------------- TASK MANAGEMENT ---------------------- */
  • #define OS_TASK_CHANGE_PRIO_EN    1    /*     Include code for OSTaskChangePrio()                      */
  • #define OS_TASK_CREATE_EN         1    /*     Include code for OSTaskCreate()                          */
  • #define OS_TASK_CREATE_EXT_EN     1    /*     Include code for OSTaskCreateExt()                       */
  • #define OS_TASK_DEL_EN            1    /*     Include code for OSTaskDel()                             */
  • #define OS_TASK_SUSPEND_EN        1    /*     Include code for OSTaskSuspend() and OSTaskResume()      */
  • #define OS_TASK_QUERY_EN          1    /*     Include code for OSTaskQuery()                           */
  •                                        /* --------------------- TIME MANAGEMENT ---------------------- */
  • #define OS_TIME_DLY_HMSM_EN       1    /*     Include code for OSTimeDlyHMSM()                         */
  • #define OS_TIME_DLY_RESUME_EN     1    /*     Include code for OSTimeDlyResume()                       */
  • #define OS_TIME_GET_SET_EN        1    /*     Include code for OSTimeGet() and OSTimeSet()             */
  •                                        /* ---------------------- MISCELLANEOUS ----------------------- */
  • #define OS_SCHED_LOCK_EN          1    /*     Include code for OSSchedLock() and OSSchedUnlock()       */
  • #define OS_TICKS_PER_SEC        200    /* Set the number of ticks in one second                        */
  • typedef INT16U             OS_FLAGS;   /* Date type for event flag bits (8, 16 or 32 bits)             */
继承事业,薪火相传
