- 来自
- 燕山大学
索引 [Index] ······· 2~10
用于PFC电源的IC [ICs for PFC Power Supply] ·······11
用于隔离型开关电源的IC [ICs for DC/DC Converter] ························13
用于系统电源的IC [System Power Management ICs] ·······················14
并联稳压器 [Shunt Regulators] ········15
三端稳压器 [3 Terminal Regulators] ·····················16,17
充电器IC [Charger ICs] ····················18
复位IC(电压检测器) [Reset ICs(Voltage Detectors) ·19
运算放大器 [Operational Amplifiers] ·················· 20~22
电压比较器 [Voltage Comparators] ··23
I/O扩展器 [I/O Expanders] ···············24
标准带包装规格 [Standard Taping Specifications] ····25
型号的命名方法 [Part No. Destination] ················26,27
封装代码 [Package Code]················28
封装 [Package] ·······29
封装和标准带包装规格 [Package and Standard Taping Specifications] ················30,31
内置电阻的晶体管 ···32
双极性晶体管 ·····33,34
用于高频放大器的小信号Bip-TRSs [Small Signal Bip-TRSs for High Frequency Amplifier] ················34
用于一般放大器的小信号TRSs [Small Signal TRSs for General Amplifier] ················34
用于高频放大器的功率MOSFET [Power MOSFETs for High Frequency Amplifier] ····35
用于高频放大器的双MOSFET [Twin-type MOSFETs for High Frequency Amplifier] ··35
用于高频放大器的小信号MOSFET [Small Signal MOSFETs for High Frequency Amplifier] ···············35
用于一般放大器的小信号MOSFET [Small Signal MOSFETs for General Amplifier] ···35
用于小信号开关的MOSFET(μFET) [Small Signal Switching use MOSFET(μFET)] ···35
结型场效应晶体管(J-FET) ················35
型号的命名方法 [Part No. Destination] ·············· 36~38
用于一般开关的功率MOSFET [Power MOSFETs for General Switching] ··········· 39~47
用于一般放大器的功率MOSFET [Power MOSFETs for General Amplifier] ················48
功率MOSFET [Power MOSFETs]
小功率MOSFET ····················48
小信号MOSFET ····················49
用于手机电池保护的功率MOSFET ················49
用于PC/电池保护的功率MOSFET [Power MOSFETs for Protection use of PC and Battery] ···50
内置热关断功能的MOSFET [Thermal Shut Down Functioned MOSFET] ·······51
驱动器IC/MOSFET集成SiP(DrMOS) [Driver IC-MOSFET Integrated SiP(DrMOS)] ·················51
用于车载的功率MOSFET [Power MOSFETs for Automobile use] ···················51
智能功率器件 ··········51
IGBT 普通用的IGBT [IGBTs for General use] ···········52
用于闪光灯的IGBT [IGBTs for Strobe use] ····52
用于PDP的IGBT [IGBTs for PDP use] ···········52
用于点火器的IGBT [IGBTs for Lgniter use] ····52
双向晶闸管 [Triacs] ·53
晶闸管 [Thyristors] ··54
晶体管阵列 ··············54
标准包装规格 [Standard Packaging Specifications] ·55
标准带包装规格 [Standard Taping Specifications] ····56
封装 [Package] ·······57
封装和标准带包装规格 [Package and Standard Taping Specifications] ·············· 58~61
贴面封装产品标记一览表 [Surface Mount Type Marking] ··················62
Renesas VP~瑞萨 功率MOSFET模拟站点
[Renesas VP~Renesas Power MOSFETs Simulation Site] ···············62
资料下载: v02-Renesas-晶体管晶闸管双向晶闸管通用IC选型手册.pdf (3.34 MB, 下载次数: 12) 3 天前 上传
下载次数: 12
瑞萨晶体管/晶闸管/双向晶闸管/通用IC选型手册
下载积分: 积分 -1 |
