- 来自
- 燕山大学
Install "android-tools" package (adb and fastboot) in Ubuntu 12.04, 11.10 or 11.04
Like I've said above, android-tools is available in the official Ubuntu 12.10 repositories so all you have to do is search for it in Ubuntu Software Center and click the install button.
For Ubuntu 12.04, 11.10 and 11.04, you can install android-tools using the main WebUpd8 PPA:
sudo add-apt-repository ppa:nilarimogard/webupd8sudo apt-get updatesudo apt-get install android-tools-adb android-tools-fastboot
Once installed, run "adb" and "fastboot" in a terminal to see the available options and how to use these Android tools.
Configuring USB Access
Under GNU/linux systems (and specifically under Ubuntu systems), regular users can't directly access USB devices by default. The system needs to be configured to allow such access.
The recommended approach is to create a file /etc/udev/rules.d/51-android.rules (as the root user) and to copy the following lines in it. <username> must be replaced by the actual username of the user who is authorized to access the phones over USB.
# adb protocol on passion (Nexus One)SUBSYSTEM=="usb", ATTR{idVendor}=="18d1", ATTR{idProduct}=="4e12", MODE="0666", OWNER="<username>"# fastboot protocol on passion (Nexus One)SUBSYSTEM=="usb", ATTR{idVendor}=="0bb4", ATTR{idProduct}=="0fff", MODE="0666", OWNER="<username>"# adb protocol on crespo/crespo4g (Nexus S)SUBSYSTEM=="usb", ATTR{idVendor}=="18d1", ATTR{idProduct}=="4e22", MODE="0666", OWNER="<username>"# fastboot protocol on crespo/crespo4g (Nexus S)SUBSYSTEM=="usb", ATTR{idVendor}=="18d1", ATTR{idProduct}=="4e20", MODE="0666", OWNER="<username>"# adb protocol on stingray/wingray (Xoom)SUBSYSTEM=="usb", ATTR{idVendor}=="22b8", ATTR{idProduct}=="70a9", MODE="0666", OWNER="<username>"# fastboot protocol on stingray/wingray (Xoom)SUBSYSTEM=="usb", ATTR{idVendor}=="18d1", ATTR{idProduct}=="708c", MODE="0666", OWNER="<username>"# adb protocol on maguro/toro (Galaxy Nexus)SUBSYSTEM=="usb", ATTR{idVendor}=="04e8", ATTR{idProduct}=="6860", MODE="0666", OWNER="<username>"# fastboot protocol on maguro/toro (Galaxy Nexus)SUBSYSTEM=="usb", ATTR{idVendor}=="18d1", ATTR{idProduct}=="4e30", MODE="0666", OWNER="<username>"# adb protocol on panda (PandaBoard)SUBSYSTEM=="usb", ATTR{idVendor}=="0451", ATTR{idProduct}=="d101", MODE="0666", OWNER="<username>"# fastboot protocol on panda (PandaBoard)SUBSYSTEM=="usb", ATTR{idVendor}=="0451", ATTR{idProduct}=="d022", MODE="0666", OWNER="<username>"# usbboot protocol on panda (PandaBoard)SUBSYSTEM=="usb", ATTR{idVendor}=="0451", ATTR{idProduct}=="d00f", MODE="0666", OWNER="<username>"# usbboot protocol on panda (PandaBoard ES)SUBSYSTEM=="usb", ATTR{idVendor}=="0451", ATTR{idProduct}=="d010", MODE="0666", OWNER="<username>"# adb protocol on grouper (Nexus 7)SUBSYSTEM=="usb", ATTR{idVendor}=="18d1", ATTR{idProduct}=="4e42", MODE="0666", OWNER="<username>"# fastboot protocol on grouper (Nexus 7)SUBSYSTEM=="usb", ATTR{idVendor}=="18d1", ATTR{idProduct}=="4e40", MODE="0666", OWNER="<username>"Those new rules take effect the next time a device is plugged in. It might therefore be necessary to unplug the device and plug it back into the computer.
#sudo service udev restart
#fastboot command |
