/*管脚初始化*/
void CAN_PinInit(void)
GPIO_InitTypeDef GPIO_InitStructure;
/* Configure CAN pin: RX */
GPIO_InitStructure.GPIO_Pin = PIN_CAN_RX;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
GPIO_Init(GPIO_CAN, &GPIO_InitStructure);
/* Configure CAN pin: TX */
GPIO_InitStructure.GPIO_Pin = PIN_CAN_TX;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;//GPIO_Mode_Out_PP;
/*CAN1配置函数*/
void CAN_Configuration(void)
CAN_InitTypeDef CAN_InitStructure;
CAN_FilterInitTypeDef CAN_FilterInitStructure;
// CAN register init
CAN_DeInit(CAN1);
CAN_StructInit(&CAN_InitStructure);
// CAN cell init
CAN_InitStructure.CAN_TTCM=DISABLE;//禁止时间触发通信模式
CAN_InitStructure.CAN_ABOM=DISABLE;
CAN_InitStructure.CAN_AWUM=DISABLE;//睡眠模式通过清除sleep位来唤醒
CAN_InitStructure.CAN_NART=ENABLE;//ENABLE;报文自动重传
CAN_InitStructure.CAN_RFLM=DISABLE;//接收溢出时,FIFO未锁定
CAN_InitStructure.CAN_TXFP=DISABLE;//发送的优先级由标示符的大小决定
CAN_InitStructure.CAN_Mode=CAN_Mode_Normal;//正常模式下
//设置can通讯波特率为50Kbps
CAN_InitStructure.CAN_SJW=CAN_SJW_1tq;
CAN_InitStructure.CAN_BS1=CAN_BS1_8tq;
CAN_InitStructure.CAN_BS2=CAN_BS2_7tq;
CAN_InitStructure.CAN_Prescaler=45;
CAN_Init(CAN1,&CAN_InitStructure);
// CAN filter init
CAN_FilterInitStructure.CAN_FilterNumber=0;
CAN_FilterInitStructure.CAN_FilterMode=CAN_FilterMode_IdMask;
CAN_FilterInitStructure.CAN_FilterScale=CAN_FilterScale_32bit;//CAN_FilterScale_16bit; //32bit
CAN_FilterInitStructure.CAN_FilterIdHigh = (((u32)slave_id<<21)&0xffff0000)>>16;
CAN_FilterInitStructure.CAN_FilterIdLow =(((u32)slave_id<<21)|CAN_ID_STD|CAN_RTR_DATA)&0xffff;
CAN_FilterInitStructure.CAN_FilterMaskIdHigh = 0xFFFF;
CAN_FilterInitStructure.CAN_FilterMaskIdLow = 0xFFFF;
CAN_FilterInitStructure.CAN_FilterFIFOAssignment=CAN_FIFO0;
CAN_FilterInitStructure.CAN_FilterActivation=ENABLE;
//时能过滤器
CAN_FilterInit(&CAN_FilterInitStructure);
CAN_ITConfig(CAN1,CAN_IT_FMP0|CAN_IT_EPV, ENABLE);
