复制代码FATFS底层读数据函数:
- DRESULT disk_read (
- BYTE drv, /* Physical drive nmuber (0..) */
- BYTE *buff, /* Data buffer to store read data */
- DWORD sector, /* Sector address (LBA) */
- BYTE count /* Number of sectors to read (1..255) */
- if( !count )
- return RES_PARERR; /* count不能等于0,否则返回参数错误 */
- switch (drv)
- case 0:
- if(count==1) /* 1个sector的读操作 */
- return RES_OK;
- else /* 多个sector的读操作 */
- return RES_OK;
- case 1:
- return RES_OK;
- return RES_OK;
- default:
- return RES_ERROR;
复制代码
FATFS底层写数据函数:
- DRESULT disk_write (
- const BYTE *buff, /* Data to be written */
- BYTE count /* Number of sectors to write (1..255) */
- if( !count )
- switch (drv)
- case 0:
- if(count==1) /* 1个sector的写操作 */
- return RES_OK;
- else /* 多个sector的写操作 */
- return RES_OK;
- case 1:
- return RES_OK;
- return RES_OK;
- default:return RES_ERROR;
复制代码
FATFS磁盘控制函数:
- DRESULT disk_ioctl (
- BYTE ctrl, /* Control code */
- void *buff /* Buffer to send/receive control data */
- if (drv==0)
- switch (ctrl)
- case CTRL_SYNC :
- return RES_OK;
- case GET_SECTOR_COUNT :
- return RES_OK;
- case GET_BLOCK_SIZE :
- return RES_OK;
- case CTRL_POWER :
- break;
- case CTRL_LOCK :
- break;
- case CTRL_EJECT :
- break;
- /* MMC/SDC command */
- case MMC_GET_TYPE :
- break;
- case MMC_GET_CSD :
- break;
- case MMC_GET_CID :
- break;
- case MMC_GET_OCR :
- break;
- case MMC_GET_SDSTAT :
- break;
- }else if(drv==1){
- switch (ctrl)
- case CTRL_SYNC :
- return RES_OK;
- return RES_OK;
- case GET_SECTOR_SIZE :
- return RES_OK;
- return RES_OK;
- case CTRL_POWER :
- break;
- case CTRL_LOCK :
- break;
- case CTRL_EJECT :
- break;
- break;
- break;
- break;
- break;
- break;
- else{
