stm32使用内部RC晶振(2)
stm32使用内部RC晶振(2)
void RCC_PCLK1Config(u32 RCC_HCLK)
  u32 tmpreg = 0;  /* Check the parameters */
  assert_param(IS_RCC_PCLK(RCC_HCLK));
  tmpreg = RCC->CFGR;
  /* Clear PPRE1[2:0] bits */
  tmpreg &= CFGR_PPRE1_Reset_Mask;
  /* Set PPRE1[2:0] bits according to RCC_HCLK value */
  tmpreg |= RCC_HCLK;
  /* Store the new value */
  RCC->CFGR = tmpreg;
* Function Name  : RCC_PCLK2Config
* Description    : Configures the High Speed APB clock (PCLK2).
* Input          : - RCC_HCLK: defines the APB2 clock divider. This clock is
*                    derived from the AHB clock (HCLK).
*                    This parameter can be one of the following values:
*                       - RCC_HCLK_Div1: APB2 clock = HCLK
*                       - RCC_HCLK_Div2: APB2 clock = HCLK/2
*                       - RCC_HCLK_Div4: APB2 clock = HCLK/4
*                       - RCC_HCLK_Div8: APB2 clock = HCLK/8
*                       - RCC_HCLK_Div16: APB2 clock = HCLK/16
* Output         : None
* Return         : None
* 功能           : 设置高速AHB时钟(PCLK2);
void RCC_PCLK2Config(u32 RCC_HCLK)
  u32 tmpreg = 0;
  tmpreg = RCC->CFGR;
  /* Clear PPRE2[2:0] bits */
  tmpreg &= CFGR_PPRE2_Reset_Mask;
  /* Set PPRE2[2:0] bits according to RCC_HCLK value */
  tmpreg |= RCC_HCLK << 3;
  RCC->CFGR = tmpreg;
* Function Name  : RCC_APB2PeriphClockCmd
* Description    : Enables or disables the High Speed APB (APB2) peripheral clock.
* Input          : - RCC_APB2Periph: specifies the APB2 peripheral to gates its
*                    clock.
*                    This parameter can be any combination of the following values:
*                       - RCC_APB2Periph_AFIO, RCC_APB2Periph_GPIOA, RCC_APB2Periph_GPIOB,
*                         RCC_APB2Periph_GPIOC, RCC_APB2Periph_GPIOD, RCC_APB2Periph_GPIOE,
*                         RCC_APB2Periph_GPIOF, RCC_APB2Periph_GPIOG, RCC_APB2Periph_ADC1,
*                         RCC_APB2Periph_ADC2, RCC_APB2Periph_TIM1, RCC_APB2Periph_SPI1,
*                         RCC_APB2Periph_TIM8, RCC_APB2Periph_USART1, RCC_APB2Periph_ADC3,
*                         RCC_APB2Periph_ALL
*                  - NewState: new state of the specified peripheral clock.
*                    This parameter can be: ENABLE or DISABLE.
* Output         : None
* Return         : None
* 功能           : 使能或者失能APB2外设时钟 ;
void RCC_APB2PeriphClockCmd(u32 RCC_APB2Periph, FunctionalState NewState)
  assert_param(IS_RCC_APB2_PERIPH(RCC_APB2Periph));
  assert_param(IS_FUNCTIONAL_STATE(NewState));
  if (NewState != DISABLE)
    RCC->APB2ENR |= RCC_APB2Periph;
  else
    RCC->APB2ENR &= ~RCC_APB2Periph;
继承事业,薪火相传
