2:任务的恢复
#if OS_TASK_SUSPEND_EN > 0
INT8U OSTaskResume (INT8U prio)
OS_TCB *ptcb;
#if OS_CRITICAL_METHOD == 3 /* Storage for CPU status register */
OS_CPU_SR cpu_sr = 0;
#endif
#if OS_ARG_CHK_EN > 0
if (prio >= OS_LOWEST_PRIO) { /* Make sure task priority is valid */
return (OS_ERR_PRIO_INVALID);
#endif
OS_ENTER_CRITICAL();
ptcb = OSTCBPrioTbl[prio];
if (ptcb == (OS_TCB *)0) { /* Task to suspend must exist */
OS_EXIT_CRITICAL();
return (OS_ERR_TASK_RESUME_PRIO);
if (ptcb == OS_TCB_RESERVED) { /* See if assigned to Mutex */
OS_EXIT_CRITICAL();
return (OS_ERR_TASK_NOT_EXIST);
if ((ptcb->OSTCBStat & OS_STAT_SUSPEND) != OS_STAT_RDY) { /* Task must be suspended */
ptcb->OSTCBStat &= ~(INT8U)OS_STAT_SUSPEND; /* Remove suspension */
if (ptcb->OSTCBStat == OS_STAT_RDY) { /* See if task is now ready */
if (ptcb->OSTCBDly == 0) {
OSRdyGrp |= ptcb->OSTCBBitY; /* Yes, Make task ready to run */
OSRdyTbl[ptcb->OSTCBY] |= ptcb->OSTCBBitX;
OS_EXIT_CRITICAL();
if (OSRunning == OS_TRUE) {
OS_Sched(); /* Find new highest priority task */
} else {
OS_EXIT_CRITICAL();
} else { /* Must be pending on event */
OS_EXIT_CRITICAL();
return (OS_ERR_NONE);
OS_EXIT_CRITICAL();
return (OS_ERR_TASK_NOT_SUSPENDED);
#endif
其中主要的代码如下:
OS_EXIT_CRITICAL();
} else {
OS_EXIT_CRITICAL();
OS_EXIT_CRITICAL();
看之前复习一下几个变量的值:
#if OS_LOWEST_PRIO <= 63
ptcb->OSTCBY = (INT8U)(prio >> 3); /* Pre-compute X, Y, BitX and BitY */
ptcb->OSTCBX = (INT8U)(prio & 0x07);
ptcb->OSTCBBitY = (INT8U)(1 << ptcb->OSTCBY);
ptcb->OSTCBBitX = (INT8U)(1 << ptcb->OSTCBX);
#else
ptcb->OSTCBY = (INT8U)((prio >> 4) & 0xFF); /* Pre-compute X, Y, BitX and BitY */
ptcb->OSTCBX = (INT8U) (prio & 0x0F);
ptcb->OSTCBBitY = (INT16U)(1 << ptcb->OSTCBY);
ptcb->OSTCBBitX = (INT16U)(1 << ptcb->OSTCBX);
#endif
在OS_LOWEST_PRIO <= 63时,ptcb->OSTCY和ptcb->OSTCBX的最大值为:8。
ptcb->OSTCY表示的是就绪表中的下标,ptcb->OSTCBX表示的是:OSRdyTbl[ptcb->OSTCBY]中的第ptcb->OSTCBXbit位的值。
在明确一下就用:ptcb->OSTCBBitY和ptcb->OSTCBBitX。这俩个分别表示的是某一bit位。
有了上面的值,函数OSTaskResume()很好理解,设置就绪表,是任务处于就绪状态,并进行一次任务调度。 |
