#include "fsmc_nor.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define Bank1_NOR2_ADDR ((u32)0x64000000)
/* Delay definition */
#define BlockErase_Timeout ((u32)0x00A00000)
#define ChipErase_Timeout ((u32)0x30000000)
#define Program_Timeout ((u32)0x00001400)
/* Private macro -------------------------------------------------------------*/
#define ADDR_SHIFT(A) (Bank1_NOR2_ADDR + (2 * (A)))
#define NOR_WRITE(Address, Data) (*(vu16 *)(Address) = (Data)) /* Private variables ---------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/ /* Private functions ---------------------------------------------------------*/
/******************************************************************************* * Function Name : FSMC_NOR_Init
* Description : Configures the FSMC and GPIOs to interface with the NOR memory.
* This function must be called before any write/read operation * on the NOR.
* Input : None
* Output : None
* Return : None
*******************************************************************************/ void FSMC_NOR_Init(void)
FSMC_NORSRAMInitTypeDef FSMC_NORSRAMInitStructure; FSMC_NORSRAMTimingInitTypeDef p;
GPIO_InitTypeDef GPIO_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD |
RCC_APB2Periph_GPIOE |
RCC_APB2Periph_GPIOF | RCC_APB2Periph_GPIOG, ENABLE);
/*-- GPIO Configuration ------------------------------------------------------*/ /* NOR Data lines configuration */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_8 | GPIO_Pin_9 |
GPIO_Pin_10 | GPIO_Pin_14 | GPIO_Pin_15; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOD, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 |
GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
GPIO_Init(GPIOE, &GPIO_InitStructure);
/* NOR Address lines configuration */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 |
GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_12 |
GPIO_Pin_13 |
GPIO_Init(GPIOF, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_4 |
GPIO_Pin_5;
GPIO_Init(GPIOG, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 | GPIO_Pin_12 |
GPIO_Pin_13;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6;
/* NOE and NWE configuration */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5;
/* NE2 configuration */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
/*-- FSMC Configuration ----------------------------------------------------*/ p.FSMC_AddressSetupTime = 0x05; /*ADDSET 地址建立时间*/ p.FSMC_AddressHoldTime = 0x00; /*ADDHOLD 地址保持时间*/ p.FSMC_DataSetupTime = 0x07; /*DATAST 数据建立时间*/
p.FSMC_BusTurnAroundDuration = 0x00; /*BUSTURN 总线返转时间*/ p.FSMC_CLKDivision = 0x00; /*CLKDIV 时钟分频*/
p.FSMC_DataLatency = 0x00; /*DATLAT 数据保持时间*/
p.FSMC_AccessMode = FSMC_AccessMode_B; /*访问模式*/
FSMC_NORSRAMInitStructure.FSMC_Bank =
FSMC_Bank1_NORSRAM2; // NOR/SRAM的存储块,共4个选项
博泰典藏网btdcw.com包含总结汇报、高中教育、经管营销、行业论文、计划方案、农林牧渔、外语学习、工程科技、表格模板、高等教育、旅游景点以及STM32-FSMC-NOR FLASH等内容。 |
