linux 2.6下编译usb驱动和arm板进行数据通信(6)
static void lcd_disconnect(struct usb_interface *interface)
struct usb_lcd *dev;
int minor = interface->minor;
/* prevent skel_open() from racing skel_disconnect() */
mutex_lock(&usb_lcd_open_mutex);
dev = usb_get_intfdata(interface);
usb_set_intfdata(interface, NULL);
/* give back our minor */
usb_deregister_dev(interface, &lcd_class);
mutex_unlock(&usb_lcd_open_mutex);
/* decrement our usage count */
kref_put(&dev->kref, lcd_delete);
info("USB LCD #%d now disconnected", minor);
static struct usb_driver lcd_driver = {
.name = "usblcd",
.probe = lcd_probe,
.disconnect = lcd_disconnect,
.id_table = id_table,
static int __init usb_lcd_init(void)
int result;
result = usb_register(&lcd_driver);
if (result)
err("usb_register failed. Error number %d", result);
return result;
static void __exit usb_lcd_exit(void)
usb_deregister(&lcd_driver);
module_init(usb_lcd_init);
module_exit(usb_lcd_exit);
MODULE_AUTHOR("Georges Toth ");
MODULE_DESCRIPTION(DRIVER_VERSION);
MODULE_LICENSE("GPL");
luther@gliethttp:~/work/kernel/module_drivers/gliethttp_flash$ echo "obj-m:=gliethttp_flash.o" > Makefile
luther@gliethttp:~/work/kernel/module_drivers/gliethttp_flash$ make -C /lib/modules/`uname -r`/build M=`pwd` modules
make: Entering directory `/usr/src/linux-headers-2.6.22-14-generic'
CC [M] /home/luther/work/kernel/module_drivers/gliethttp_flash/gliethttp_flash.o
Building modules, stage 2.
MODPOST 1 modules
CC /home/luther/work/kernel/module_drivers/gliethttp_flash/gliethttp_flash.mod.o
LD [M] /home/luther/work/kernel/module_drivers/gliethttp_flash/gliethttp_flash.ko
make: Leaving directory `/usr/src/linux-headers-2.6.22-14-generic'
luther@gliethttp:~/work/kernel/module_drivers/gliethttp_flash$ ls /dev/gliethttp_flash0
luther@gliethttp:~/work/kernel/module_drivers/gliethttp_flash$ |
