linux 2.6下编译usb驱动和arm板进行数据通信(8)
BOOL OpenUsbPort (long int DelayTime)
    char Message[100];
    unsigned long int Seconds, count=100;
    BOOL DeviceFound = FALSE,MessageEnable = TRUE;
    struct termios options, old_options;
    int file;
    file = open(DeviceName, O_RDWR);
    if (file < 0)
        printf("ERROR: Open driver failed:%d \n", errno);
        return FALSE;
    usb_fd = file;
    usb_dbg("%s end, usb_fd %d\n", __func__, usb_fd);
    return TRUE;
BOOL WriteUsb (WTPCOMMAND WtpCmd,DWORD dwCmdSize)
    char Message[100];
    int result;
    DWORD IOCTL_CMD, dwActualBytes = 0;
    BOOL IsOk;
    if (usb_fd == 0)
        sprintf (Message,"  Error: OpenUsbPort must be called prior to calling WriteUsb!");
        usb_dbg("%s %d USB COMMUNICATIONS ERROR\n", __func__, __LINE__);
        return FALSE;
    result = write( usb_fd, &WtpCmd, dwCmdSize);
    if (result < 0)
        sprintf (Message,"  Error: WriteUsb failed with error %d", result);
    if (dbg_level)
        sprintf (Message,"IOCTL code: %X",IOCTL_CMD);
        usb_dbg("%s %d USB write %d bytes\n", __func__, __LINE__, result);
    return TRUE;
BOOL ReadUsb(WTPSTATUS *WtpStatus, DWORD dwSize, PDWORD pBytesRead)
    int result;
    usb_dbg("%s %d USB read %d bytes\n", __func__, __LINE__, dwSize);
    result = read(usb_fd, WtpStatus, dwSize);
    if (result <=  0)
#if ___output_log__
        printf("%s return %d\n", __func__, result);
#endif
        return FALSE;
    dbg_usbStatus(WtpStatus);
    *pBytesRead = result;
    return TRUE;
BOOL ReadUsbCharBuffer (char *WtpMessage,DWORD dwSize,PDWORD pBytesRead)
    int result;
    if (usb_fd < 0)
        printf ("  Error: OpenUsbPort must be called prior to calling ReadUsb!");
        return FALSE;
    result = read(usb_fd, WtpMessage, dwSize);
    if (result < 0 )
        printf ("  Error: ReadFile failed with error\n");
        return FALSE;
    if (*pBytesRead != dwSize) return FALSE;
    return TRUE;
void CloseUsbPort ()
    if (usb_fd != 0) close (usb_fd);
继承事业,薪火相传
