FPGA verilog 实现的1602 时钟计数器 (转)
熬夜到了1点了,终于写出了1602的时钟计数器代码。为什么是时钟计数器呢?
因为我还没来得及做校准时间,所以只能称之为时钟计数器,不能成为电子钟。
网上很少用人公开这一类代码,一搜FPGA  1602,都是写一个静态的显示,在实际应用中,是没有用的,因此这个简单的例子,给大家抛砖引玉了!
上代码: Qii 9.0编译过,21EDA 开发板测试OK
module LCD
  rst,
  key1,
  clk,
  rw,
  rs,
  en,
  data
input clk,rst,key1;
output rs,en,rw;
output [7:0] data;
reg rs,en_sel;
reg [7:0] data;
reg [7:0] shi,fen,miao;
reg [31:0]count,count1;  //LCD CLK 分频计数器
reg lcd_clk;
reg [7:0] one_1,one_2,one_3,one_4,one_5,one_6,one_7,one_8,one_9,one_10,one_11,one_12,one_13,one_14,one_15,one_16;
reg [7:0] two_1,two_2,two_3,two_4,two_5,two_6,two_7,two_8,two_9,two_10,two_11,two_12,two_13,two_14,two_15,two_16;
reg [7:0] next,xianshi,two;
parameter state0  =8'h00,     //设置8位格式,2行,5*7    8'h38;
    state1  =8'h01,  //整体显示,关光标,不闪烁  8'h0C    闪烁 8'h0e
    state2  =8'h02,  //设定输入方式,增量不移位 8'h06
    state3  =8'h03,  //清除显示     8'h01
    state4  =8'h04,  //显示第一行的指令  80H
    state5  =8'h05,  //显示第二行的指令  80H+40H
    scan =8'h06,
    nul  =8'h07;
parameter data0  =8'h10,   //2行,共32个数据
    data1  =8'h11,
    data2  =8'h12,
    data3  =8'h13,
    data4  =8'h14,
    data5  =8'h15,
    data6  =8'h16,
    data7  =8'h17,
    data8  =8'h18,
    data9  =8'h19,
    data10  =8'h20,
    data11  =8'h21,
    data12  =8'h22,
    data13  =8'h23,
    data14  =8'h24,
    data15  =8'h25,
    data16  =8'h26,
    data17 =8'h27,
    data18 =8'h28,
    data19 =8'h29,
    data20 =8'h30,
    data21  =8'h31,
    data22  =8'h32,
    data23  =8'h33,
    data24  =8'h34,
    data25  =8'h35,
    data26  =8'h36,
    data27  =8'h37,
    data28  =8'h38,
    data29  =8'h39,
    data30  =8'h40,
    data31  =8'h41;
initial           //初始值
begin
   //第一行显示 TEL:13868160569
   one_1<="T"; one_2<="E"; one_3<="L"; one_4<=":"; one_5<="1"; one_6<="3"; one_7<="8"; one_8<="6";
   one_9<="8";one_10<="1";one_11<="6";one_12<="0";one_13<="5";one_14<="6";one_15<="9";one_16<=" ";
   //第二行显示 Clock:00-00-00
   two_1<="C"; two_2<="l"; two_3<="o"; two_4<="c"; two_5<="k"; two_6<=":"; two_7<=" "; two_8<=" ";
   two_9<="-";two_10<=" ";two_11<=" ";two_12<="-";two_13<=" ";two_14<=" ";two_15<=" ";two_16<=" ";
   shi<=0;fen<=0;miao<=0;
end
always @(posedge clk )   //获得LCD时钟
begin
  count<=count+1;
  if(count==250000)
  begin
   count<=0;
   lcd_clk<=~lcd_clk;
  end
end
继承事业,薪火相传
