Xilinx Spartan6 LX150T开发方案(2)
MultiBoot support for remote upgrade with multiple bitstreams, using watchdog protection          Enhanced security for design protection
          Unique Device DNA identifier for design authentication
          AES bitstream encryption in the larger devices
          Faster embedded processing with enhanced, low cost, MicroBlaze?soft processor
          Industry-leading IP and reference designs
          Spartan- 6 FPGA系列产品:
          图1.Spartan- 6 FPGA系列汽车娱乐框图
          图2.Spartan- 6 FPGA系列平板显示器框图
          图3.Spartan- 6 FPGA系列视频监视框图
          Xilinx Spartan-6 LX150T开发板
          The Xilinx Spartan-6 LX150T Development Kit provides a complete development platform for designing and verifying applications based on the Xilinx Spartan-6 LXT FPGA family. Available with the Spartan-6 LX150T, the kit enables designers to prototype high-performance designs with ease, while providing expandability and customization through the dual FMC LPC expansion slots.
          The Spartan-6 LX150T system board is available with the LX150T device (XC6SLX150T-3FGG676)。 Serial gigabit transceiver interface (GTPs) provide connection to the on-chip PCI Express® x1 hard macro or a PCI Express x4 soft macro, one SFP connector, and a SATA Host interface. The system board includes DDR3 SDRAM, Flash memory, a 10/100/1000 Ethernet PHYs, and a serial port. Other board features include a USB port, a programmable LVDS clock, user switches, and LEDs. The board also provides two FMC LPC expansion slots, providing a total of 136 high-speed, single-ended and differential user I/O. FMC modules can be easily added to the board for additional application specific functions.
          Xilinx Spartan-6 LX150T开发板主要特性:
          FPGA
          — Xilinx Spartan-6 XC6SLX150T-3FGG676C FPGA
          I/O Connectors
          — Two FMC LPC general-purpose I/O expansion connectors
          — One SD card connector
          — Avnet LCD Interface (ALI) connector
          RocketIO™ GTP Transceiver Connectors
          — One Small-Form Pluggable (SFP) cage
          — Two transceivers supplied on an FMC connectors for use by an expansion module
          — One PCI Express add-in card interface (4 lanes @ 2.5 Gbps)
          — One SATA host connector
          Memory
          — 128 MB DDR3 SDRAM components
          — 32 MB FLASH
          Communication
          — RS-232 serial port
          — USB 2.0
          — USB-RS232 Port
          — 10/100/1000 Ethernet port
继承事业,薪火相传
