Master-Worker模式的核心思想是,系统由两类进程协作工作:Master进程和Worker进程。Master进程负责接收和分配任务,Worker进程负责处理子任务。当Worker进程将各个子任务处理完成后,将结果返回给Master进程,由Master进程做归纳和汇总。
工作示意图如下图所示:
它的优势在于将一个大的任务分解成一个个的子任务并行执行,提高程序执行效率。
代码示例:
Master进程类:
public class Master {
protected Queue<Object> workQueue = new ConcurrentLinkedQueue<Object>();//存放子任务
protected Map<String,Thread> threadMap = new HashMap<String,Thread>();//存放Worker线程
protected Map<String,Object> resultMap = new ConcurrentHashMap<String, Object>();//存放返回结果集
public boolean isCompleted(){
for(Map.Entry<String,Thread> entry:threadMap.entrySet()){
if(entry.getValue().getState() != Thread.State.TERMINATED){
return false;
return true;
public Master(Worker worker,int countWorker){
worker.setWorkQueue(workQueue);
worker.setResultMap(resultMap);
for(int i=0;i<countWorker;i++){//创建多个Worker线程
threadMap.put(Integer.toString(i),new Thread(worker,Integer.toString(i)));
public void submit(Object job){
workQueue.add(job);//将任务加到子任务队列中
public Map<String,Object> getResultMap(){
return resultMap;
public void execute(){
//循环启动Worker线程
entry.getValue().start();
Worker进程类:
public class Worker implements Runnable{
protected Queue<Object> workQueue;
protected Map<String,Object> resultMap;
public void setWorkQueue(Queue<Object> workQueue){
this.workQueue = workQueue;
public void setResultMap( Map<String,Object> resultMap){
this.resultMap = resultMap;
public Object handle(Object input){
return input;
public void run(){
while(true){
Object input = workQueue.poll();//从子任务中取任务执行
if(input == null) break;
Object re = handle(input);//这是一个模板方法模式
resultMap.put(Integer.toString(input.hashCode()),re);
PlusWorker进程类:
public class PlusWorker extends Worker {
Integer i = (Integer)input;
return i*i*i;
