linux下的串口编程—线程接收(2)
linux下的串口编程—线程接收(2)
void*        com_recv_upper(void *param)
        uint8_t        recv_buffer[COM_BUFFER_SIZE] = {0};
        int32_t        len    = 0;
        while(1)
        if(upper_device_comfd > 0)
        memset(recv_buffer,0,sizeof(recv_buffer));
        len = read(upper_device_comfd,recv_buffer,sizeof(recv_buffer));
        if(len > 0)    printf("com recv thread : %s\n",recv_buffer);
        else    // 串口异常或是关闭了
        break;
        pthread_exit(0);
        //用pthread_exit()来调用线程的返回值,用来退出线程,但是退出线程所占用的资源不会随着线程的终止而得到释放
        return NULL;
        /* 串口的初始化 */
        int32_t        com_init_upper(void *param)
        int32_t    ret = 0;
        upper_device_comfd = open(UPPER_DEVICE_COM,O_RDWR | O_NOCTTY | O_NDELAY);
        if(upper_device_comfd< 0)
        ret = -COM_OPEN_ERROR;
        else
        if((ret = _com_set_upper()) == OPER_OK)
        if((ret = pthread_create(&com_recv_threadid,NULL,com_recv_upper,NULL))!= 0)
        ret = -THREAD_CREATE_ERROR;
        return ret;
        /* 串口的发送
        * 返回值: 正常返回发送的字节数,0表示没有数据需要发送。
        *            -1表示异常,也可通过errno获取异常码.
        int32_t        com_send_upper(uint8_t *send_buffer,int32_t buffer_len)
        int32_t    ret = 0;
        // 疑问1:发送数据的长度是否需要判断有效值,有效值是多少??
        ret = write(upper_device_comfd, send_buffer, buffer_len);
        return ret;
        /* 串口参数设置
        * 波特率,停止位,校验位,流控制,异步同步等
        int32_t        com_set_upper(void *param)
        int32_t    ret = 0;
        return ret;
        /* 串口设置参数生效 */
        int32_t        com_set_effect_upper(void *param)
        int32_t    ret = 0;
        return ret;
        /* 串口关闭*/
        int32_t        com_close_upper(void *param)
        int32_t    ret = 0;
        if(upper_device_comfd > 0 )
        close(upper_device_comfd);
        upper_device_comfd = 0;
        return ret;
        /* 串口接收线程关闭 */
        int32_t        com_recv_thread_close(void *param)
        int32_t    ret = 0;
        pthread_join(com_recv_threadid,NULL);
        return ret;
        * upper,上位机
继承事业,薪火相传
