![Rank: 6](images/default/star_level3.gif) ![Rank: 6](images/default/star_level2.gif)
此外部中断的设置我完全是采用了寄存器的操作,没有用一个库函数来实现的,这样做设置是很慢的,一位一位的校准,但是我喜欢这样做。效果如同我想的一样!!!!!!!!!!,与天津第四项目部宿舍
- #include "stm32f10x.h"
- GPIO_InitTypeDef GPIO_InitStructure;
- void mysysint();
- void my_EXTI_int();
- int main(void)
- mysysint();//RCC初始化,时钟设置72MHZ
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE);//使能APB2时钟
- /* Configure PD0 and PD2 in output pushpull mode */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9| GPIO_Pin_10| GPIO_Pin_11;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_Init(GPIOD, &GPIO_InitStructure);
- my_EXTI_int();
- while(1);
- void my_EXTI_int()//呼呼!
- /* PA8被我设置成输入,上啦、下拉 */
- GPIOA->CRH=0x44444448;
- /*配置PA的8-11脚为中断输入线*/
- AFIO->EXTICR[2]=0x0;
- /*设置外部中断线8中断请求开启其他的都关闭*/
- EXTI->IMR=0x00000100;
- /*下降沿触发*/
- EXTI->FTSR=0x00000100;
- /*EXTI9_5的优先级设为10*/
- NVIC->IP[23]=10;
- /*开启23号中断即EXTI9_5,关闭其他所有外部的中断*/
- NVIC->ISER[0]=0x00800000;
- void mysysint()//系统初始化程序
- ErrorStatus HSEStartUpStatus;//说明标志位
- RCC_DeInit();//所有外设全部缺省设置
- /* Enable HSE */
- RCC_HSEConfig(RCC_HSE_ON);
- /* Wait till HSE is ready and if Time out is reached exit */
- HSEStartUpStatus = RCC_WaitForHSEStartUp();
- if(HSEStartUpStatus == SUCCESS)//启动成功
- /*这两条FLASH指令必须加上,不知为啥?不加上就运行几秒后出错,参照系统初始化*/
- /* Enable The Prefetch Buffer */
- FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);//FLASH缓存开启
- /* Configure the Latency cycle: Set 2 Latency cycles */
- FLASH_SetLatency(FLASH_Latency_2); //设置FLASH这些位表示SYSCLK(系统时钟)周期与闪存访问时间的比例,为010:两个等待状态,当 48MHz < SYSCLK ≤ 72MHz
- /* Set PLL clock output to 72MHz using HSE (8MHz) as entry clock */
- RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);//外部时钟为8M,PLL的输入时钟=8MHZ,倍频系数9,
- /* Configure HCLK such as HCLK = SYSCLK */
- RCC_HCLKConfig(RCC_SYSCLK_Div1);//设置了啦AHB分频器的分频系数=1,即HCLK=SYSCLK=72MHZ
- /* Configure PCLK1 such as PCLK1 = HCLK/2 */
- RCC_PCLK1Config(RCC_HCLK_Div2);//设置了APB1外设的时钟频率最大是36M这里是APB1的分频器设为2,PCLK1=HCLK/2=72/2=36MHZ正好是最大值
- /* Configure PCLK2 such as PCLK2 = HCLK */
- RCC_PCLK2Config(RCC_HCLK_Div1);//设置PLCK2=HCLK=72MHZ,的APB2分频器=1
- /* Select the PLL as system clock source */
- RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);//设置了SYSCLK的提供者为PLL,频率由上面算出=72MHZ
- /* disable PLL Ready interrupt */
- RCC_ITConfig(RCC_IT_PLLRDY, DISABLE);//PLL中断关闭
- RCC_ITConfig(RCC_IT_HSERDY,DISABLE);//HSE中断关闭
- RCC_ITConfig(RCC_IT_HSIRDY, DISABLE); //HSI中断关闭
- RCC_ITConfig(RCC_IT_LSERDY, DISABLE); //LSE中断关闭
- RCC_ITConfig(RCC_IT_LSIRDY, DISABLE); //LSI中断关闭
- /* PLL clock divided by 1.5 used as USB clock source */
- RCC_USBCLKConfig(RCC_USBCLKSource_PLLCLK_1Div5);//设置USB的时钟为=72、1.5=48mhz
- /* Configure ADCCLK such as ADCCLK = PCLK2/2 */
- RCC_ADCCLKConfig(RCC_PCLK2_Div2);//设置ADC时钟=PCLK2/2= 36MHZ
- /* disable the LSE */
- RCC_LSEConfig(RCC_LSE_OFF);//外部低速晶振关闭
- /*DISable the RTC clock */
- RCC_RTCCLKCmd(DISABLE);
- /* DISable the Clock Security System */
- RCC_ClockSecuritySystemCmd(DISABLE);
- /* Enable the PLL */
- RCC_PLLCmd(ENABLE);//使能PLL
- /* PLL ans system clock config */
- else
- /* Add here some code to deal with this error */
复制代码 |
