把北航那本书中的"10010序列检测"改少了F和G状态: module seqdet(x,z,clk,rst); input x,clk,rst; output z; reg[2:0]state; wire z; parameter IDLE=3'd0, A=3'd1, B=3'd2, C=3'd3, D=3'd4, E=3'd5, assign z=(state==D&&x==0)?1:0; always@(posedge clk or negedge rst) if(!rst) begin state<=IDLE; end else casex(state) IDLE:if(x==1) state<=A; A: if(x==0) state<=B; B: if(x==0) state<=C; else state<=A; C: if(x==1) state<=D; else state<=IDLE; D: if(x==0) state<=E; else state<=A; E: if(x==0) state<=C; else state<=A; default:state<=IDLE; endcase endmodule
结果是红色那句"assign语法出错",怎么回事? 谢谢! |
