java 如何根据线程id找到线程(2)
     * Get a list of all daemon threads.  An empty array is
     * returned if there are no daemon threads.
     * @return      an array of daemon threads
    public static Thread[] getAllDaemonThreads( )
        final Thread[] allThreads = getAllThreads( );
        final Thread[] daemons = new Thread[allThreads.length];
        int nDaemon = 0;
        for ( Thread thread : allThreads )
            if ( thread.isDaemon( ) )
                daemons[nDaemon++] = thread;
        return java.util.Arrays.copyOf( daemons, nDaemon );
     * Get a list of all threads with a given thread state.
     * Thread states are defined in the Thread.State enum for
     * the Thread class.  Principal thread states include
     * RUNNABLE, WAITING, TIMED_WAITING, and BLOCKED.  An
     * empty array is returned if there are no threads in
     * the chosen state.
     * @param   state   the state to look for
     * @return      an array of threads in that state
    public static Thread[] getAllThreads( final Thread.State state )
        final Thread[] found = new Thread[allThreads.length];
        int nFound = 0;
            if ( thread.getState( ) == state )
                found[nFound++] = thread;
        return java.util.Arrays.copyOf( found, nFound );
     * Get the thread with the given name.  A null is returned
     * if no such thread is found.  If more than one thread has
     * the same name, the first one found is returned.
     * @param   name    the thread name to search for
     * @return      the thread, or null if not found
     * @throws  NullPointerException
     *          if the name is null
    public static Thread getThread( final String name )
        if ( name == null )
            throw new NullPointerException( "Null name" );
        final Thread[] threads = getAllThreads( );
        for ( Thread thread : threads )
            if ( thread.getName( ).equals( name ) )
                return thread;
        return null;
     * Get the thread with the given ID.  A null is returned
     * @param   id  the thread ID to search for
    public static Thread getThread( final long id )
            if ( thread.getId( ) == id )
                return thread;
        return null;
     * Get the thread for the given thread info.  A null
     * is returned if the thread cannot be found.
     * @param   info    the thread info to search for
     *          if info is null
    public static Thread getThread( final ThreadInfo info )
        if ( info == null )
            throw new NullPointerException( "Null info" );
        return getThread( info.getThreadId( ) );
// ThreadInfo
     * Get a list of all thread info objects.  Since there is
     * always at least one thread running, there is always at
     * least one thread info object.  This method never returns
     * a null or empty array.
     * @return      an array of thread infos
    public static ThreadInfo[] getAllThreadInfos( )
        final ThreadMXBean thbean =
            ManagementFactory.getThreadMXBean( );
        final long[] ids = thbean.getAllThreadIds( );
        // Get thread info with lock info, when available.
        ThreadInfo[] infos;
        if ( !thbean.isObjectMonitorUsageSupported( ) ||
            !thbean.isSynchronizerUsageSupported( ) )
            infos = thbean.getThreadInfo( ids );
        else
            infos = thbean.getThreadInfo( ids, true, true );
        // Clean nulls from array if threads have died.
        final ThreadInfo[] notNulls = new ThreadInfo[infos.length];
        int nNotNulls = 0;
        for ( ThreadInfo info : infos )
            if ( info != null )
                notNulls[nNotNulls++] = info;
        if ( nNotNulls == infos.length )
            return infos;   // Original had no nulls
        return java.util.Arrays.copyOf( notNulls, nNotNulls );
     * Get the thread info for the thread with the given name.
     * A null is returned if no such thread info is found.
     * If more than one thread has the same name, the thread
     * info for the first one found is returned.
     * @return      the thread info, or null if not found
    public static ThreadInfo getThreadInfo( final String name )
        if ( name == null )
                return getThreadInfo( thread.getId( ) );
        return null;
     * Get the thread info for the thread with the given ID.
     * @throws  IllegalArgumentException
     *          if id <= 0
    public static ThreadInfo getThreadInfo( final long id )
            return thbean.getThreadInfo( id );
        final ThreadInfo[] infos = thbean.getThreadInfo(
            new long[] { id }, true, true );
        if ( infos.length == 0 )
            return null;
        return infos[0];
     * Get the thread info for the given thread.  A null is
     * returned if the thread info cannot be found.
     * @param   thread  the thread to search for
     *          if thread is null
    public static ThreadInfo getThreadInfo( final Thread thread )
        if ( thread == null )
            throw new NullPointerException( "Null thread" );
// MonitorInfo and LockInfo
     * Get the thread holding a lock on the given object.
     * A null is returned if there is no such thread.
     * @param   object      the object to look for a lock on
     * @return          the thread holding a lock, or
     *              null if there is none
     *              if the object is null
    public static Thread getLockingThread( final Object object )
        if ( object == null )
            throw new NullPointerException( "Null object" );
        final long identity = System.identityHashCode( object );
        ThreadInfo info = null;
        MonitorInfo[] monitors = null;
            info = getThreadInfo( thread.getId( ) );
            if ( info == null )
                continue;
            monitors = info.getLockedMonitors( );
            for ( MonitorInfo monitor : monitors )
                if ( identity == monitor.getIdentityHashCode( ) )
                    return thread;
        return null;
继承事业,薪火相传
