红黑树的使用详解(2)
红黑树的使用详解(2)
 最后附上一个我自己用C写的红黑树操作。插入操作验证无误,删除操作验证次数有限,可能有bug存在。
复制代码 代码如下:
#include    <stdlib.h>
#include    <stdio.h>
#define T_nil -1
//T_nil is a key of nil[T] in the book.
#define RED        1
#define BLACK    0//T_nil is BLACK
//T_nil's p is itself. need to set.
struct rb_tree {
    int color;
    int key; //normally a positive number.
    struct rb_tree *left;
    struct rb_tree *right;
    struct rb_tree *p;
int rb_walk(struct rb_tree *node) {
    if (node->key != T_nil) {
        rb_walk(node->left);
        printf("%d, color is %s\n",node->key,(node->color?"RED":"BLACK"));
        rb_walk(node->right);
    return 1;
struct rb_tree* rb_search(struct rb_tree *node, int k) {
    if ((node->key == T_nil) || (node->key == k))
        return node;
    if ( k < node->key )
        return rb_search(node->left,k);
    else
        return rb_search(node->right,k);
struct rb_tree* tree_minimum(struct rb_tree *node) {
    if (node->key == T_nil)
        return node;
    while (node->left->key != T_nil)
        node = node->left;
    return node;
struct rb_tree* tree_maximum(struct rb_tree *node) {
        return node;
    while (node->right->key != T_nil)
        node = node->right;
    return node;
struct rb_tree* tree_successor(struct rb_tree *node) {
    struct rb_tree *y;
    if (node->right->key != T_nil)
        return tree_minimum(node->right);
    y = node->p;
    while ((y->key != T_nil) && (node == y->right)) {
        node = y;
        y = y->p;
    return y;
//3 function of below is copy from tree.
struct rb_tree * left_rotate(struct rb_tree *rb, struct rb_tree *x) {
    struct rb_tree *y;
    //if (x->right->key == T_nil) {
    //    printf("have no right child,rotation cancel.\n");
    //    return rb;
    y = x->right;
    x->right = y->left;
    if (y->left->key != T_nil)
        y->left->p = x;
    y->p = x->p;
    if    (x->p->key == T_nil)
        rb = y;
    else if (x == x->p->left)
        x->p->left = y;
    else
        x->p->right = y;
    y->left = x;
    x->p = y;
    return rb;
struct rb_tree *right_rotate(struct rb_tree *rb, struct rb_tree *x) {
    struct rb_tree *y;
    //if (x->left->key == T_nil ) {
    //    printf("have no left child,rotation cancel.\n");
    //    return rb;
    y = x->left;
    x->left = y->right;
    if (y->right->key != T_nil )
        y->right->p = x;
    y->p = x->p;
        rb = y;
        x->p->left = y;
    else
        x->p->right = y;
    y->right = x;
    x->p = y;
    return rb;
struct rb_tree* rb_insert_fixup(struct rb_tree *rb, struct rb_tree *z) {
    struct rb_tree *y;
    while (z->p->color == RED) {
        if (z->p == z->p->p->left) {
            y = z->p->p->right;
            if (y->color == RED)    {
                z->p->color = BLACK;
                y->color = BLACK;
                z->p->p->color = RED;
                z = z->p->p;
            else {
                if (z == z->p->right) {
                    z= z->p;
                    rb = left_rotate(rb,z);
                rb = right_rotate(rb,z->p->p);
        else {//same as right and left exchanged
            y = z->p->p->left;
                y->color = BLACK;
                z = z->p->p;
            else {
                if (z == z->p->left) {
                    z= z->p;
                    rb = right_rotate(rb,z);
                rb = left_rotate(rb,z->p->p);
    rb->color = BLACK;
    return rb;
struct rb_tree* rb_insert(struct rb_tree *rb, int k) {
    struct rb_tree *y = rb->p;
    struct rb_tree *x = rb;
    struct rb_tree *z;
    z= (struct rb_tree *)malloc(sizeof(struct rb_tree));
    z->key = k;
    while (x->key != T_nil) {
        y = x;
        if (k< x->key)
            x = x->left;
        else
            x = x->right;
    z->p = y;
    if (y->key == T_nil)
        rb = z;
    else if (z->key <y->key)
        y->left = z;
    else
        y->right =z;
    z->left = rb->p;
    z->right = rb->p;
    z->color = RED;
    return rb_insert_fixup(rb,z);
struct rb_tree* rb_delete_fixup(struct rb_tree *rb, struct rb_tree *x) {
    struct rb_tree *w;
    while ((x !=rb)&&(x->color == BLACK)) {
        if (x == x->p->left) {
            w = x->p->right;
            if (w->color == RED) {
                w->color = BLACK;
                x->p->color = RED;
                left_rotate(rb,x->p);
                w = x->p->right;
            if ((w->left->color == BLACK)&&(w->right->color == BLACK)) {
                w->color = RED;
                x = x->p;
            else if (w->right->color == BLACK) {
                w->left->color = BLACK;
                w->color = RED;
                right_rotate(rb,w);
                w = x->p->right;
            w->color = x->p->color;
            x->p->color = BLACK;
            w->right->color = BLACK;
            x = rb;
        else { //same as right and left exchanged
            w = x->p->left;
                w->color = BLACK;
                x->p->color = RED;
                right_rotate(rb,x->p);
                w = x->p->right;
            if ((w->right->color == BLACK)&&(w->left->color == BLACK)) {
                w->color = RED;
                x = x->p;
            else if (w->left->color == BLACK) {
                w->color = RED;
                left_rotate(rb,w);
                w = x->p->left;
            x = rb;
    x->color = BLACK;
struct rb_tree* rb_delete(struct rb_tree *rb, struct rb_tree *z) {
    struct rb_tree *x,*y;
    if ((z->left->key == T_nil) || (z->right->key == T_nil))
        y = z;
    else y = tree_successor(z);
        x = y->left;
    else
        x = y->right;
    x->p = y->p;
    if (y->p->key == T_nil)
        rb = x;
    else if (y==x->p->left)
        y->p->left = x;
    else
        y->p->right = x;
    if (y!=x) //copy y's data to z
        z->key = y->key;
    if (y->color == BLACK)
        rb_delete_fixup(rb,x);
    free(y);
    return rb;
int main () {
    struct rb_tree *p,*root;
    struct rb_tree tree_nil = {BLACK,T_nil,&tree_nil,&tree_nil,&tree_nil};
    root = &tree_nil;
    root = rb_insert(root,15);
    root = rb_insert(root,5);
    root = rb_insert(root,16);
    root = rb_insert(root,3);
    root = rb_insert(root,12);
    root = rb_insert(root,20);
    root = rb_insert(root,10);
    root = rb_insert(root,13);
    root = rb_insert(root,6);
    root = rb_insert(root,7);
    root = rb_insert(root,18);
    root = rb_insert(root,23);
    rb_walk(root);
    p = rb_search(root,18);
    root = rb_delete(root,p);
    rb_walk(root);
    return 1;
继承事业,薪火相传
