TMS320F28335的GPIO
TMS320F28335的GPIO
F28335有三种32位的I/O口,依次PORTA(GPIO0-GPIO31),  PORTB(GPIO32-GPIO63),  PORTC(GPIO64-GPIO87),这些口都可以配置为普通的数字IO口同样也能被配置为外部接口。这样涉及到了IO的寄存器,IO口共有三类寄存器:控制寄存器、数据寄存器和中断控制寄存器。下面依次介绍这些寄存器。
  • struct GPIO_CTRL_REGS {
  •    union  GPACTRL_REG  GPACTRL;      // GPIO A Control Register (GPIO0 to 31)
  •    union  GPA1_REG        GPAQSEL1;   // GPIO A Qualifier Select 1 Register (GPIO0 to 15)
  •    union  GPA2_REG        GPAQSEL2;   // GPIO A Qualifier Select 2 Register (GPIO16 to 31)
  •    union  GPA1_REG        GPAMUX1;    // GPIO A Mux 1 Register (GPIO0 to 15)
  •    union  GPA2_REG        GPAMUX2;    // GPIO A Mux 2 Register (GPIO16 to 31)
  •    union  GPADAT_REG    GPADIR;              // GPIO A Direction Register (GPIO0 to 31)
  •    union  GPADAT_REG    GPAPUD;      // GPIO A Pull Up Disable Register (GPIO0 to 31)
  •    Uint32                 rsvd1;
  •    union  GPBCTRL_REG  GPBCTRL;     // GPIO B Control Register (GPIO32 to 63)
  •    union  GPB1_REG        GPBQSEL1;  // GPIO B Qualifier Select 1 Register (GPIO32 to 47)
  •    union  GPB2_REG        GPBQSEL2;  // GPIO B Qualifier Select 2 Register (GPIO48 to 63)
  •    union  GPB1_REG        GPBMUX1;   // GPIO B Mux 1 Register (GPIO32 to 47)
  •    union  GPB2_REG        GPBMUX2;   // GPIO B Mux 2 Register (GPIO48 to 63)
  •    union  GPBDAT_REG    GPBDIR;      // GPIO B Direction Register (GPIO32 to 63)
  •    union  GPBDAT_REG    GPBPUD;     // GPIO B Pull Up Disable Register (GPIO32 to 63)
  •    Uint16                rsvd2[8];
  •    union  GPC1_REG        GPCMUX1;   // GPIO C Mux 1 Register (GPIO64 to 79)
  •    union  GPC2_REG        GPCMUX2;   // GPIO C Mux 2 Register (GPIO80 to 95)
  •    union  GPCDAT_REG    GPCDIR;      // GPIO C Direction Register (GPIO64 to 95)
  •    union  GPCDAT_REG    GPCPUD;    // GPIO C Pull Up Disable Register (GPIO64 to 95)
复制代码
       其中GPXCTRL寄存器的作用是设置采样窗周期T=2*GPXCTRL*Tsysclk;GPxQSEL中每两位控制一个引脚,确定是3周期采样还是6周期采样或者不用采样;GPxMUX的功能很简单就是配置各个引脚的功能,或者是数字IO口,或者是外部接口。同样是两位控制一个引脚;GPxDIR是控制每个引脚的输入或是输出,0是输入,1是输出。还有一个GPxPUD寄存器,是用来使能或禁止指定接口的内部上拉。以上这些就是属于IO口的控制寄存器。下面的是IO数据类寄存器所有集合
  • struct GPIO_DATA_REGS {
  •    union  GPADAT_REG     GPADAT;         // GPIO Data Register (GPIO0 to 31)
  •    union  GPADAT_REG     GPASET;         // GPIO Data Set Register (GPIO0 to 31)
  •    union  GPADAT_REG     GPACLEAR;     // GPIO Data Clear Register (GPIO0 to 31)
  •    union  GPADAT_REG     GPATOGGLE;   // GPIO Data Toggle Register (GPIO0 to 31)
  •    union  GPBDAT_REG     GPBDAT;         // GPIO Data Register (GPIO32 to 63)
  •    union  GPBDAT_REG     GPBSET;         // GPIO Data Set Register (GPIO32 to 63)
  •    union  GPBDAT_REG     GPBCLEAR;     // GPIO Data Clear Register (GPIO32 to 63)
  •    union  GPBDAT_REG     GPBTOGGLE;   // GPIO Data Toggle Register (GPIO32 to 63)
  •    union  GPCDAT_REG     GPCDAT;         // GPIO Data Register (GPIO64 to 95)
  •    union  GPCDAT_REG     GPCSET;         // GPIO Data Set Register (GPIO64 to 95)
  •    union  GPCDAT_REG     GPCCLEAR;     // GPIO Data Clear Register (GPIO64 to 95)
  •    union  GPCDAT_REG     GPCTOGGLE;   // GPIO Data Toggle Register (GPIO64 to 95)
  •    Uint16                  rsvd1[8];};这些寄存器就是为了写数据,读数据用的。再下面就是中断寄存器struct GPIO_INT_REGS {
  •    union  GPIOXINT_REG     GPIOXINT1SEL; // XINT1 GPIO Input Selection
  •    union  GPIOXINT_REG     GPIOXINT2SEL; // XINT2 GPIO Input Selection
  •    union  GPIOXINT_REG     GPIOXNMISEL;  // XNMI_Xint13 GPIO Input Selection
  •    union  GPIOXINT_REG     GPIOXINT3SEL; // XINT3 GPIO Input Selection
  •    union  GPIOXINT_REG     GPIOXINT4SEL; // XINT4 GPIO Input Selection
  •    union  GPIOXINT_REG     GPIOXINT5SEL; // XINT5 GPIO Input Selection
  •    union  GPIOXINT_REG     GPIOXINT6SEL; // XINT6 GPIO Input Selection
  •    union  GPIOXINT_REG     GPIOXINT7SEL; // XINT7 GPIO Input Selection
  •    union  GPADAT_REG       GPIOLPMSEL;   // Low power modes GP I/O input select
复制代码
       以上就是IO口的外部中断寄存器,我们可以对上面GPIO0-GPIO63进行外部中断配置。
继承事业,薪火相传
