- Routine mpsplot: To plot the normalized power spectum curve on the
- normalized frequency axis from -.5 to +.5 .
- mfre : Points in frequency axis and must be the power of 2.
- ts : Sample interval in seconds (real).
- psdr : Real array of power spectral density values.
- psdi : Real work array.
- in chapter 11,12
- void mpsplot(float psdr[],float psdi[],int mfre,float ts)
- FILE *fp;
- char filename[30];
- int k,m2;
- float pmax,fs,faxis;
- m2=mfre/2;
- for(k=0;k<m2;k++){
- psdi[k]=psdr[k];
- psdr[k]=psdr[k+m2];
- psdr[k+m2]=psdi[k];
- pmax=psdr[0];
- for(k=1;k<mfre;k++)
- if(psdr[k]>pmax)
- pmax=psdr[k];
- for(k=0;k<mfre;k++) {
- psdr[k]=psdr[k]/pmax;
- if(psdr[k]<=0.0)
- psdr[k]=.000001;
- fs=1./ts;
- fs=fs/(float)(mfre);
- printf("Please input filename:\n");
- scanf("%s",filename);
- if((fp=fopen(filename,"w"))==NULL) {
- printf("cannot open file\n");
- exit(0);
- faxis=fs*(k-m2);
- fprintf(fp,"%f,%f\n",faxis,10.*log10(psdr[k]));
- fclose(fp);
- return;
- Routine mar1psd: To compute the power spectum by AR-model parameters.
- Input parameters:
- ip : AR model order (integer)
- ep : White noise variance of model input (real)
- a : Complex array of AR parameters a(0) to a(ip)
- Output parameters:
- in chapter 12
- void mar1psd(complex a[],int ip,int mfre,float *ep,float ts)
- static
float psdr[4096]; - static
float psdi[4096]; - int k;
- float p;
- for(k=0;k<=ip;k++) {
- psdr[k]=a[k].real;
- psdi[k]=a[k].imag;
- for(k=ip+1;k<mfre;k++) {
- psdr[k]=0.;
- psdi[k]=0.;
- mrelfft(psdr,psdi,mfre,-1);
- p=pow(psdr[k],2)+pow(psdi[k],2);
- psdr[k]=(*ep)*ts/p;
- mpsplot(psdr,psdi,mfre,ts);
- return;
- * Below are examples for using @maryuwa and @mar1psd
- #define PI (3.1415926)
- #define N (1024)
- #define AN (10)
- complex x[N];
- complex r[N];
- complex a[AN];
- * generate random number which satify guass distribution
- double guass_rand(void)
- static
double V1, V2, S; - static
int phase = 0; - double X;
- if ( phase == 0 ) {
- do {
- double U1 = (double)rand() / RAND_MAX;
- double U2 = (double)rand() / RAND_MAX;
- V1 = 2 * U1 - 1;
- V2 = 2 * U2 - 1;
- S = V1 * V1 + V2 * V2;
- } while(S >= 1 || S == 0);
- X = V1 * sqrt(-2 * log(S) / S);
- } else {
- X = V2 * sqrt(-2 * log(S) / S);
- phase = 1 - phase;
- return X;
- void zx_ar_model(void)
- int i=0;
- float ep = 0;
- int ierror = 0;
- * generate x[N]
- srand(time(NULL));
- for (i=0; i<N; i++) {
- x.real = sin(2*PI*i/N) + guass_rand();
- x.imag = 0;
- /* Find parameters for AR model */
- maryuwa(x, a, r, N, AN, &ep, &ierror);
- /* Calculate power spectum using parameters of AR model */
- mar1psd(a, AN, N, &ep, 1);
- * main.c
- * Created on: 2013-8-11
- * Author: monkeyzx
- #include "ar_model.h"
- int main(void)
- zx_ar_model();
- return 0;
上面的实例中给定输入信号为余弦信号,采样点数为1024个点,通过计算后的功率谱通过mpsplot函数保存到文本文件output.txt中,保存格式如下:-0.500000,-15.334630
-0.499023,-15.334833
-0.498047,-15.335444
-0.497070,-15.336456
-0.496094,-15.337864
-0.495117,-15.339655
-0.494141,-15.341816
-0.493164,-15.344331
-0.492188,-15.347179
-0.491211,-15.350342
-0.490234,-15.353794
-0.489258,-15.357505
-0.488281,-15.361453
-0.487305,-15.365603
-0.486328,-15.369924
-0.485352,-15.374381
最后借助matlab读取该文件,绘制出功率谱的图形
- data = load('output.txt');
- plot(data(:,1),data(:,2));
