从编译器源码中提取ARMv8的指令编码
从编译器源码中提取ARMv8的指令编码
问题1:提取ARMv8的指令编码答:ARMv8指令的opcode可以在支持ARMv8的编译器binutils中找到,该工具能在网上找到,见参考资料[1],或者在[1]中搜索aarch64_opcode_table。
       为了说明指令编码细节,现将网页中部分内容摘录如下:
1208 struct aarch64_opcode aarch64_opcode_table[] =
1209 {
1210  /* Add/subtract (with carry).  */
1211  {"adc", 0x1a000000, 0x7fe0fc00, addsub_carry, 0, CORE, OP3 (Rd, Rn, Rm), QL_I3SAMER, [url=]F_SF[/url]},
1212  {"adcs", 0x3a000000, 0x7fe0fc00, addsub_carry, 0, CORE, OP3 (Rd, Rn, Rm), QL_I3SAMER, F_SF},
以上结构体中的每一项对应某条指令的操作码等信息,其中aarch64_opcode结构体(见参考文献[2])在,内容摘录如下:
structaarch64_opcode
  /*The name of the mnemonic.  */
const char *name;
  /*The opcode itself.  Those bits which willbe filled in with operands are zeroes. */
aarch64_insn opcode;
  /*The opcode mask.  This is used by thedisassembler.  This is a mask containingones indicating those bits which must match the opcode field, and zeroesindicating those bits which need not match (and are presumably filled in byoperands).  */
aarch64_insn mask;
enum aarch64_insn_class iclass;
  /*Enumerator identifier.  */
enum aarch64_op op;
  /*Which architecture variant provides this instruction.  */
const aarch64_feature_set *avariant;
  /*An array of operand codes.  Each code isan index into the operand table.  Theyappear in the order which the operands must appear in assembly code, and are terminatedby a zero.  */
enum aarch64_opnd operands[AARCH64_MAX_OPND_NUM];
  /*A list of operand qualifier code sequence. Each operand qualifier code qualifies the corresponding operandcode.  Each operand qualifier sequencespecifies a valid opcode variant and related constraint on operands.  */
aarch64_opnd_qualifier_seq_t qualifiers_list[AARCH64_MAX_QLF_SEQ_NUM];
  /*Flags providing information about this instruction */
uint32_t flags;
按照以上信息解释aarch64_opcode_table中的结构体如下表:
"adc",
0x1a000000
0x7fe0fc00
addsub_carry,
CORE
OP3 (Rd, Rn, Rm)
QL_I3SAMER,
F_SF
助记符
操作码
操作码掩码
指令所属类
枚举器标识符
提供这种指令的结构体变量
操作数编码数组
操作数限定符的代码序列列表
指令信息标志位
1:Aarch64-opc.c中有关于指令位域的定义。
const aarch64_field fields[] =
   {  0,  0 },      /*NIL.  */
   {  0,  4 },      /*cond2: condition in truly conditional-executed inst.  */
   {  0,  4 },      /*nzcv: flag bit specifier, encoded in the "nzcv" field.  */
   {  5,  5 },      /*defgh: d:e:f:g:h bits in AdvSIMD modified immediate.  */
    {16,  3 },       /*abc: a:b:c bits in AdvSIMD modified immediate. */
   {  5, 19 },       /* imm19: e.g. in CBZ. */
   {  5, 19 },       /* immhi: e.g. in ADRP. */
    {29,  2 },       /*immlo: e.g. in ADRP.  */
    {22,  2 },       /*size: in most AdvSIMD and floating-point instructions.  */
    {10,  2 },       /*vldst_size: size field in the AdvSIMD load/store inst.  */
    {29,  1 },       /*op: in AdvSIMD modified immediate instructions. */
    {30,  1 },       /*Q: in most AdvSIMD instructions.  */
   {  0,  5 },      /*Rt: in load/store instructions.  */
   {  0,  5 },      /*Rd: in many integer instructions.  */
   {  5,  5 },      /*Rn: in many integer instructions.  */
    {10,  5 },       /*Rt2: in load/store pair instructions.  */
    {10,  5 },       /*Ra: in fp instructions.  */
   {  5,  3 },      /*op2: in the system instructions.  */
   {  8,  4 },      /*CRm: in the system instructions.  */
    {12,  4 },       /*CRn: in the system instructions.  */
    {16,  3 },       /*op1: in the system instructions.  */
    {19,  2 },       /*op0: in the system instructions.  */
    {10,  3 },       /*imm3: in add/sub extended reg instructions. */
    {12,  4 },       /*cond: condition flags as a source operand. */
    {12,  4 },       /*opcode: in advsimd load/store instructions. */
    {12,  4 },       /*cmode: in advsimd modified immediate instructions.  */
    {13,  3 },       /*asisdlso_opcode: opcode in advsimd ld/st single element.  */
    {13,  2 },       /*len: in advsimd tbl/tbx instructions.  */
    {16,  5 },       /*Rm: in ld/st reg offset and some integer inst. */
    {16,  5 },       /*Rs: in load/store exclusive instructions. */
    {13,  3 },       /*option: in ld/st reg offset + add/sub extended reg inst.  */
    {12,  1 },       /*S: in load/store reg offset instructions. */
    {21,  2 },       /*hw: in move wide constant instructions. */
    {22,  2 },       /*opc: in load/store reg offset instructions. */
    {23,  1 },       /*opc1: in load/store reg offset instructions. */
    {22,  2 },       /*shift: in add/sub reg/imm shifted instructions. */
    {22,  2 },       /*type: floating point type field in fp data inst.  */
    {30,  2 },       /*ldst_size: size field in ld/st reg offset inst. */
    {10,  6 },       /*imm6: in add/sub reg shifted instructions. */
    {11,  4 },       /*imm4: in advsimd ext and advsimd ins instructions.  */
    {16,  5 },       /*imm5: in conditional compare (immediate) instructions.  */
    {15,  7 },       /*imm7: in load/store pair pre/post index instructions.  */
    {13,  8 },       /*imm8: in floating-point scalar move immediate inst.  */
    {12,  9 },       /*imm9: in load/store pre/post index instructions.  */
    {10, 12 },         /* imm12: in ld/stunsigned imm or add/sub shifted inst.  */
   {  5, 14 },       /* imm14: in test bit and branch instructions.  */
   {  5, 16 },       /* imm16: in exception instructions.  */
   {  0, 26 },       /* imm26: in unconditional branch instructions.  */
    { 10, 6 },       /* imms: in bitfield andlogical immediate instructions.  */
    {16,  6 },       /*immr: in bitfield and logical immediate instructions.  */
    {16,  3 },       /*immb: in advsimd shift by immediate instructions.  */
    {19,  4 },       /*immh: in advsimd shift by immediate instructions.  */
    {22,  1 },       /*N: in logical (immediate) instructions. */
    {11,  1 },       /*index: in ld/st inst deciding the pre/post-index.  */
    {24,  1 },       /*index2: in ld/st pair inst deciding the pre/post-index.  */
    {31,  1 },       /*sf: in integer data processing instructions. */
    {11,  1 },       /*H: in advsimd scalar x indexed element instructions.  */
    {21,  1 },       /*L: in advsimd scalar x indexed element instructions.  */
    {20,  1 },       /*M: in advsimd scalar x indexed element instructions.  */
    {31,  1 },       /*b5: in the test bit and branch instructions. */
    {19,  5 },       /*b40: in the test bit and branch instructions. */
    {10,  6 },       /*scale: in the fixed-point scalar to fp converting inst.  */
2、函数aarch64_opcode_encode用于将操作数插入opcode中
