ARM linux内核在内存中的布局
ARM linux内核在内存中的布局
This document describes the virtual memory layout which the Linuxkernel uses for ARM processors.  It indicates which regions arefree for platforms to use, and which are used by generic code.The ARM CPU is capable of addressing a maximum of 4GB virtual memoryspace, and this must be shared between user space processes, thekernel, and hardware devices.As the ARM architecture matures, it becomes necessary to reservecertain regions of VM space for use for new facilities; thereforethis document may reserve more VM space over time.Start                End                Use--------------------------------------------------------------------------ffff8000        ffffffff        copy_user_page / clear_user_page use.                                For SA11xx and Xscale, this is used to                                setup a minicache mapping.ffff1000        ffff7fff        Reserved.                                Platforms must not use this address range.ffff0000        ffff0fff        CPU vector page.                                The CPU vectors are mapped here if the                                CPU supports vector relocation (control                                register V bit.)ffc00000        fffeffff        DMA memory mapping region.  Memory returned                                by the dma_alloc_xxx functions will be                                dynamically mapped here.ff000000        ffbfffff        Reserved for future expansion of DMA                                mapping region.VMALLOC_END        feffffff        Free for platform use, recommended.                                VMALLOC_END must be aligned to a 2MB                                boundary.VMALLOC_START        VMALLOC_END-1        vmalloc() / ioremap() space.                                Memory returned by vmalloc/ioremap will                                be dynamically placed in this region.                                VMALLOC_START may be based upon the value                                of the high_memory variable.PAGE_OFFSET        high_memory-1        Kernel direct-mapped RAM region.                                This maps the platforms RAM, and typically                                maps all platform RAM in a 1:1 relationship.TASK_SIZE        PAGE_OFFSET-1        Kernel module space                                Kernel modules inserted via insmod are                                placed here using dynamic mappings.00001000        TASK_SIZE-1        User space mappings                                Per-thread mappings are placed here via                                the mmap() system call.00000000        00000fff        CPU vector page / null pointer trap                                CPUs which do not support vector remapping                                place their vector page here.  NULL pointer                                dereferences by both the kernel and user                                space are also caught via this mapping.Please note that mappings which collide with the above areas may resultin a non-bootable kernel, or may cause the kernel to (eventually) panicat run time.Since future CPUs may impact the kernel mapping layout, user programsmust not access any memory which is not mapped inside their 0x0001000to TASK_SIZE address range.  If they wish to access these areas, theymust set up their own mappings using open() and mmap().
