Warning: The Reserve All Unused Pins setting has not been specified, and will default to 'As output driving ground'. Warning: Found pins functioning as undefined clocks and/or memory enables Info: Assuming node "clk" is an undefined clock 虽然warning不影响下载,但看了实在想弄清楚到底为什么出这些问题.所以贴出来,请高手指教啊 谢谢了 |
