一个键的长短按
一个键的长短按
有三个键,分别是 KEY_PLAY  KEY_UP  KEY_DOWN
#define KEY_PLAY  0
#define KEY_UP   1
#define KEY_DOWN  2
#define KEY_DEL  3
#define KEY_PORT  0
#define KEY_PORT_PU  0_PU
#define KEY_PORT_DDR  0_DDR
#define KEY_MARK  (BIT(KEY_DEL)|BIT(KEY_DOWN)|BIT(KEY_UP)|BIT(KEY_PLAY))
#define KEY_0S_PLAY BIT(KEY_PLAY)
#define KEY_0S_UP BIT(KEY_UP)
#define KEY_0S_DOWN BIT(KEY_DOWN)
#define KEY_0S_DEL BIT(KEY_DEL)
#define KEY_1S_PLAY BIT(KEY_PLAY+4)
#define KEY_1S_UP BIT(KEY_UP+4)
#define KEY_1S_DOWN BIT(KEY_DOWN+4)
#define KEY_1S_DEL BIT(KEY_DEL+4)
#define KEY_2S_PLAY BIT(KEY_PLAY+8)
#define KEY_2S_UP BIT(KEY_UP+8)
#define KEY_2S_DOWN BIT(KEY_DOWN+8)
#define KEY_2S_DEL BIT(KEY_DEL+8)
#define KEY_REP_PLAY BIT(KEY_PLAY+12)
#define KEY_REP_UP BIT(KEY_UP+12)
#define KEY_REP_DOWN BIT(KEY_DOWN+12)
#define KEY_REP_DEL BIT(KEY_DEL+12)
现在KEY_PLAY可以长短按,其他两个却不行!
void Key_Scan( void )
 Key_IO_Set();
 if( keydataio = (~KEY_PORT)&KEY_MARK )
  if( PowerDownCount ) PowerDownCount = ModePower;
  if( keydata == keydataio )
   if( !(keycnt%keyrepcount) ) pub_keydata |= (keydata&0xF)<<12;
   if( keycnt++ <= KEY_CNT2S )
    if( keycnt == KEY_CNT2S ) pub_keydata |= (keydata&0x9)<<8;
    if( keycnt == KEY_CNT0S+1 ) pub_keydata |= (keydata&0x6);
   keycnt &= 0x7FFFU;
  else keydata = keydataio;
 else
  if( keycnt )
   if( keycnt < KEY_CNT2S ) pub_keydata |= (keydata&0x9)<<4;
   keycnt = 0;
  if( PowerDownCount ) PowerDownCount--;
 Key_IO_Clear();
 if( Time_Count ) Time_Count--;
有人知道怎么设置不!?
