用 JavaServer Faces 2 实现可扩展 UI (8)
该按钮由 login 组件的界面公开,如清单 16 所示:清单 16. login 组件1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
| <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml"
xmlns:f="http://java.sun.com/jsf/core"
xmlns:h="http://java.sun.com/jsf/html"
xmlns:composite="http://java.sun.com/jsf/composite">
<!-- INTERFACE -->
<composite:interface>
<composite:actionSource name="loginButton" targets="form:loginButton"/>
<composite:attribute name="loginButtonText" default="Log In" required="true"/>
<composite:attribute name="loginPrompt"/>
<composite:attribute name="namePrompt"/>
<composite:attribute name="passwordPrompt"/>
<composite:attribute name="loginAction"
method-signature="java.lang.String action()"/>
<composite:attribute name="managedBean"/>
</composite:interface>
<!-- IMPLEMENTATION -->
<composite:implementation>
<h:form id="form" prependId="false">
<div class="prompt">
#{cc.attrs.loginPrompt}
</div>
<panelGrid columns="2">
#{cc.attrs.namePrompt}
<h:inputText id="name" value="#{cc.attrs.managedBean.name}"/>
#{cc.attrs.passwordPrompt}
<h:inputSecret id="password" value="#{cc.attrs.managedBean.password}" />
</panelGrid>
<p>
<h:commandButton id="loginButton"
value="#{cc.attrs.loginButtonText}"
action="#{cc.attrs.loginAction}"/>
</p>
</h:form>
<div class="error" style="padding-top:10px;">
<h:messages layout="table"/>
</div>
</composite:implementation>
</html>
在 login 组件的界面,我已经在 loginButton 名称下公开了 Log In 按钮。该名称所针对的是位于 form 表单内的 Log In 按钮,因此 targets 属性的值为:form:loginButton。
与 内的 Log In 按钮相关联的动作侦听器如清单 17 所示:
清单 17. Log In 按钮的动作侦听器1
2
3
4
5
6
7
8
9
10
11
12
| package com.clarity;
import javax.faces.event.AbortProcessingException;
import javax.faces.event.ActionEvent;
import javax.faces.event.ActionListener;
public class LoginActionListener implements ActionListener {
public void processAction(ActionEvent e)
throws AbortProcessingException {
System.out.println("logging in ...........");
内的动作侦听器完全是为了展示的目的 — 当用户登录时,我只简单地将一条消息写出到 servlet 容器日志文件。但是我希望您能体会到这样一个概念:有了 JSF 2,您可以实现完全可配置的组件,并且还可以向这些组件附加功能,所有这些均不需要任何 Java 代码或 XML 配置。这才真正称得上是功能强大。 |
