ERROR:HDLCompilers:27 - "start_module.v" line 2 Illegal redeclaration of 'start_module' 我写了两个模块,现写了一个顶层模块要把它们联起来,好写测试用,可是要检查这个TOP文件语法时,出现上面的错误。 TOP文件如下 : `timescale 1ns / 1ns `include "state.v" `include "start_module.v" module start_top(clock,reset,init_evoke,start_work,start_evoke, key_start, scan_work,scan_evoke); input clock, reset; output init_evoke, start_work,start_evoke, scan_evoke,scan_work, key_start; reg init_evoke, start_work,start_evoke, scan_evoke,scan_work, key_start; state A(clock,reset,init_evoke,start_work,start_evoke,scan_work,scan_evoke); //state 是这前定义过的模块 start_module B (reset,start_evoke,key_startscan_work); //start_module endmodule
其中start_module定义如下: `timescale 1ns / 1ns
module start_module(reset,start_evoke, key_start, scan_work); input reset; input start_evoke; input key_start; output scan_work; reg scan_work; always @(posedge key_start or posedge start_evoke or negedge reset) begin if(!reset) scan_work = 0; else if ((start_evoke == 1)&(key_start == 1)) begin scan_work = 1; end end endmodule 大家帮忙看看这是什么错误
[此贴子已经被作者于2007-10-6 11:19:16编辑过] |
