/* TMS320F2812 FFT 源 码(包 括 详 细 的 注释 语句) Fast Fourier Transform (FFT). Using 8 points, takes about 1.2 ms to execute one FFT. Sets up General Purpose Timer 1 to generate events at 10 kHz. Will produce 10 kHz output on T1PWM and T1PWM pins. */ #include "system.h" #include "eva.h" #include "io2407.h" #include "adc.h" #include "interrup.h" /* Complex structure definition*/ #include "fftcmplx.h" extern void FFT(COMPLEX*Y,int N); /* FFT Function */ /* The following define gives the number of samples. */ /* It should divide exactly into 512 */ /* Should N be increased, to say to 32, then the execution */ /* time of the FFT would increase */ #define N 8 unsigned int perform_fft=0 ; /* Flag driven by interrupt */ /*************************************************************/ /* Initialise General Purpose Timers GPT1 and GPT2 */ /*************************************************************/ /* Initialise General Purpose Timer 1. */ void init_GPT1(void) { MCRA|=T1PWM ; /* Turn on T1PWM */ T1CON=0x8142 ; /* Turn off GPT1 */ GPTCONA=0x0041 ; /* Active low. */ T1PR=1475 ; /* Sample at 10 kHz */ T1CMPR=0 ; /* Duty = 0% */ T1CNT=0xFFFE ; /* Set to -2 */ T1CON=0x9142 ; /* Start timer 1 */ EVAIFRA=0xFFFF ; /* Clear any pending interrupts */ EVAIMRA|=T1PINT_FLAG ; /* Enable T1 period interrupt */ } /* Initialise General Purpose Timer 2 */ void init_GPT2(void) { MCRA|=T2PWM ; /* Turn on T2PWM */ T2CON=0x8142 ; /* Turn off GPT2 */ GPTCONA|=0x0008 ; /* Controlled from GPT1 */ T2PR=1475 ; /* Sample at 10 kHz */ T2CMPR=0 ; /* Duty cycle 0% decimal */ T2CNT=0xFFFE ; /* Set to -2 */ T2CON=0x9142 ; /* Start timer 2 */ } /**************************************************************/ void init_ADC() { /* Non Cascade for 8 measurements. */ /* Will affect RESULT0 to RESULT7 only */ /*| ADC_ACQ_PS3 | ADC_ACQ_PS2*/ ADCCTRL1=(ADC_SOFT|ADC_CPS); CHSELSEQ1=0x3210 ; /* 8 measurements 0 */ CHSELSEQ2=0x0000 ; CHSELSEQ3=0xFFFF ; CHSELSEQ4=0xFFFF ; MAX_CONV=0x0007 ; /* 8 measurements, not 0 */ /* Reset sequence at zero and software start of conversion */ ADCCTRL2=(RST_SEQ1|SOC_SEQ1); } /* No semicolon here */ /***********************************************************/ int input_buffer[N]= { 8191,8191,8191,8191,0,0,0,0 }; COMPLEX y[N]; /* Variable passed to FFT and modified */ /*********************************************************** Shuffle input buffer along one place. Put latest input from ADC into first buffer location. Input from ADCIN2 lies in range 0 to FFC0h (65472 decimal). Divide by 8 to limit range from 0 to 8184. ***********************************************************/ void shuffle_and_read(void) { signed int i ; for(i=N-1;i>0;i--) { input_buffer=input_buffer[i-1]; } input_buffer[0]=(RESULT2>>3); } /*********************************************************** Copy from input buffer to complex structure. When FFT is performed, the complex structure is overwritten by the return values. ***********************************************************/ void copy_input_to_complex(void) { unsigned int i ; for(i=0;i<N;i++) { (y).real=input_buffer; (y).imag=0 ; } } /*********************************************************** Main program Uses timers to read analog input on ADCIN2 into a buffer and then perform an 8-point FFT on it. **********************************************************/ void main(void) { signed int output1,output2 ; signed int x ; /* General purpose variable. */ signed int i ; /* Counter */ signed long temp ; init_system(); /* Initialize variables and hardware */ init_ADC(); /* Initialise ADC */ init_GPT1(); /* Turn on timer 1 */ init_GPT2(); /* Turn on timer 2 */ MCRB&=0xFFFE ; /* I/O on IOPC0 for monitoring purposes */ IMR|=INT2 ; /* Turn on INT 2 */ asm(" CLRC INTM"); /* Turn on maskable interrupts */ for(;;) { if(perform_fft!=0) { perform_fft=0 ; /* Clear flag used to start fft */ PCDATDIR=0x0101 ; /* IOPC0 high */ ADCCTRL2|=SOC_SEQ1 ; /* Start next conversion*/ copy_input_to_complex(); /* Copy inputs from receive buffer */ FFT(y,8); /* Calls generic FFT function*/ /* Determine magnitude of (y[0]).real */ /* output1 lies in range 0 to 32736 */ if((y[0]).real>0) output1=(y[0]).real ; else output1=-(y[0]).real ; /* Determine magnitude of (y[0]).real */ /* output2 lies in range -32736 to 32736 */ if((y[2]).real>0) output2=(y[2]).real ; else output2=-(y[2]).real ; /* Scale output in range 0 to 1475 */ temp=(signed long)(output1*2952); output1=(signed int)(temp>>16); T1CMPR=output1 ; temp=(signed long)(output2*2952); output2=(signed int)(temp>>16); T2CMPR=output1 ; shuffle_and_read(); /* Read in latest value from ADC */ /* and put into buffer */ PCDATDIR=0x0100 ; /* IOPC0 low */ } /* End if */ } /* End for */ }/* End main() */ /************************************************************/ /* Interrupt routine */ /* The interrupt occurs once every 0.1 ms. /* Will make perform_fft = 1 once every 20 * 0.1 ms = 2 ms */ void c_int2(void) { static unsigned int x ; if(0x0027==PIVR) { EVAIFRA|=T1PINT_FLAG ; /* Clear GPT1 period interrupt */ /* Increase if FFT with more points */ if(x<19) { x++; } else { x=0 ; perform_fft=1 ; /* Global flag to start FFT */ } } }/* End of fft.c */
