有ASIC/FPGA设计的digital & analog IP cores可以提供,如需要可email联系
-8bit 1T/2T/4T/12T MCU 8bit RISC CPU Turbo 186 V6502 V8086 16bit MCU 32bit RISC CPU IBM PowerPC405 IBM PowerPC440 IBM PowerPCPLB Audio Echo Processor 16/24 bit DSP Core 16bit audio DAC (Digital design parts)
- Interface IP: Usb1.0 Host/Device/PHY Usb2.0 Host/Device/OTG USB2.0 180nm/130nm/90nm PHY (TSMC/SMIC) USB2.0 mobile PHY PCI/PCI-X PCI-Express controller/PHY IEEE1394 Controller/PHY Ethernet 10/100/1000 Controller PHY IDE/SATA Controller/PHY Media Local BUS IP SD_MMC host controller IP LCD controller MemoryStick Host controller Smart card reader AMBA2.0/3.0 IP AMBA Interface IP DDR/DDR-II IO interface DDR-SRAM PHY SATA host/device controller SATA PHY Mobile Storage WLAN AFE IP - JPEG/JPEG2000 Encoder/Decoder/Codec Motion-JPEG MPEG2 Decoder H264/MPEG4 codec H264/MPEG4 decoder H264/MPEG4 HD encoder H264/MPEG4 HD decoder MPEG4 encoder 2D graphics 2D/3D graphics TV encoder 另外还提供各种各样得synopsys & cadence & mentor & magma 等ASIC设计EDA平台(windows & linux & Solaris版本),有需要 可以email联系详细谈。
Email: soft_cores@163.com |
这个版主不太冷
我的中电网博客:http://blog.chinaecnet.com/u/20/index.htm |
