library IEEE; use IEEE.std_logic_1164.all; use IEEE.std_logic_unsigned.all; entity RAM2RW256xM is generic(WORD_WIDTH :integer := 32 ); port( clk :in std_logic; pass :in std_logic_vector(3 downto 0); -- unused except in altera wea :in std_logic; web :in std_logic; addra :in std_logic_vector(7 downto 0); addrb :in std_logic_vector(7 downto 0); dataina :in std_logic_vector(WORD_WIDTH-1 downto 0); datainb :in std_logic_vector(WORD_WIDTH-1 downto 0); dataouta ut std_logic_vector(WORD_WIDTH-1 downto 0); dataoutb ut std_logic_vector(WORD_WIDTH-1 downto 0)); end RAM2RW256xM; architecture behavior of RAM2RW256xM is type ram_type is array(0 to 255) of Std_Logic_Vector(WORD_WIDTH-1 downto 0); signal ram:ram_type; begin process begin wait until clk'event and clk='1'; dataouta <= ram(CONV_INTEGER(addra)); dataoutb <= ram(CONV_INTEGER(addrb)); end process; process begin wait until clk'event and clk='1'; if (wea = '1') then ram(CONV_INTEGER(addra)) <= dataina; end if; if (web = '1') then ram(CONV_INTEGER(addrb)) <= datainb; end if; end process; end behavior; 上面的dual ports ram 为什么在quartus 软件下编译时间超长,而中间不提示错误呢? |
