获取树莓派当前状态和数据(温度、CPU、内存、硬盘
本篇介绍如何使用Python编写一个能输出树莓派各种状态和数据的脚本,包括CPU温度、CPU占用情况、内存占用情况和硬盘占用。
建立脚本:
sudo nano get.py
贴入如下代码:
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
import os
# Return CPU temperature as a character string
def getCPUtemperature():
    res = os.popen('vcgencmd measure_temp').readline()
    return(res.replace("temp=","").replace("'C\n",""))
# Return RAM information (unit=kb) in a list
# Index 0: total RAM
# Index 1: used RAM
# Index 2: free RAM
def getRAMinfo():
    p = os.popen('free')
    i = 0
    while 1:
        i = i + 1
        line = p.readline()
        if i==2:
            return(line.split()[1:4])
# Return % of CPU used by user as a character string
def getCPUuse():
    return(str(os.popen("top -n1 | awk '/Cpu\(s\):/ {print $2}'").readline().strip()))
# Return information about disk space as a list (unit included)
# Index 0: total disk space
# Index 1: used disk space
# Index 2: remaining disk space
# Index 3: percentage of disk used
def getDiskSpace():
    p = os.popen("df -h /")
    i = 0
    while 1:
        i = i +1
        line = p.readline()
        if i==2:
            return(line.split()[1:5])
# CPU informatiom
CPU_temp = getCPUtemperature()
CPU_usage = getCPUuse()
# RAM information
# Output is in kb, here I convert it in Mb for readability
RAM_stats = getRAMinfo()
RAM_total = round(int(RAM_stats[0]) / 1000,1)
RAM_used = round(int(RAM_stats[1]) / 1000,1)
RAM_free = round(int(RAM_stats[2]) / 1000,1)
# Disk information
DISK_stats = getDiskSpace()
DISK_total = DISK_stats[0]
DISK_used = DISK_stats[1]
DISK_perc = DISK_stats[3]
if __name__ == '__main__':
    print('')
    print('CPU Temperature = '+CPU_temp)
    print('CPU Use = '+CPU_usage)
    print('')
    print('RAM Total = '+str(RAM_total)+' MB')
    print('RAM Used = '+str(RAM_used)+' MB')
    print('RAM Free = '+str(RAM_free)+' MB')
    print('')
    print('DISK Total Space = '+str(DISK_total)+'B')
    print('DISK Used Space = '+str(DISK_used)+'B')
    print('DISK Used Percentage = '+str(DISK_perc))
然后执行:
chmod +x get.py
python get.py
预期输出结果如下:
3
4
5
6
7
8
9
10
CPU Temperature = 53.0
CPU Use = 13.5
RAM Total = 497.0 MB
RAM Used = 116.0 MB
RAM Free = 381.0 MB
DISK Total Space = 3.6GB
DISK Used Space = 1.8GB
DISK Used Percentage = 53%
