智能接收条码编辑框(1)
智能接收条码编辑框(1)
以扫码枪回车作为区分, 下次输入时自动清除
    // MyEdit.h : header file
    #pragma once
    #define WM_MYINPUT_MSG  (WM_USER + 1000)
    // CMyEdit window
    class CMyEdit : public CEdit
      DECLARE_DYNAMIC(CMyEdit)
      // Construction
    public:
      CMyEdit();
      virtual ~CMyEdit();
    public:
      BOOL m_bPostMessageMode; //消息模式?
      // Attributes
    protected:
      BOOL m_bAutoClearFlag; //自动清除标记
    protected:
      virtual BOOL PreTranslateMessage(MSG* pMsg);
    // MyEdit.cpp : implementation file
    #include "stdafx.h"
    #include "MyEdit.h"
    #ifdef _DEBUG
    #define new DEBUG_NEW
    #undef THIS_FILE
    static char THIS_FILE[] = __FILE__;
    #endif
    // CMyEdit
    IMPLEMENT_DYNAMIC(CMyEdit, CEdit)
    CMyEdit::CMyEdit()
      m_bAutoClearFlag = TRUE;
      //消息模式?
      //消息模式时,回车时将给父窗口发送WM_MYINPUT_MSG消息
      //非消息模式,回车时父窗口将收到IDOK点击消息
      m_bPostMessageMode = TRUE;
    CMyEdit::~CMyEdit()
    // CMyEdit message handlers
    BOOL CMyEdit:reTranslateMessage(MSG* pMsg)
      // TODO: Add your specialized code here and/or call the base class
      if(pMsg->message == WM_KEYDOWN)
        if(m_bAutoClearFlag) //需要清除?
          SetWindowText(_T(""));
          m_bAutoClearFlag = FALSE;
        if(pMsg->wParam == VK_RETURN) //回车
          m_bAutoClearFlag = TRUE; //标记为下次清除
          if(m_bPostMessageMode) //消息模式
            //检查输入非空时发送消息给父窗口
            CString szInput;
            GetWindowText(szInput);
            CWnd *pParent = GetParent();
            if(pParent && (!szInput.IsEmpty()))
              WPARAM wParam = GetDlgCtrlID(); //控件ID
              LPARAM lParam = (LPARAM)m_hWnd; //控件窗口句柄
              pParent->ostMessage(WM_MYINPUT_MSG, wParam, lParam);
            //阻止继续生成IDOK消息
            return TRUE;
      return CEdit:reTranslateMessage(pMsg);
