* Copyright (c) 2012-2013, Michael Yang 杨福海 (www.yangfuhai.com).
* <p>
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* <p>
* http://www.apache.org/licenses/LICENSE-2.0
* <p>
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
package com.hwc.oklib.util;
import android.content.Context;
import android.graphics.Bitmap;
import android.graphics.BitmapFactory;
import android.graphics.Canvas;
import android.graphics.PixelFormat;
import android.graphics.drawable.BitmapDrawable;
import android.graphics.drawable.Drawable;
import org.json.JSONArray;
import org.json.JSONObject;
import java.io.BufferedReader;
import java.io.BufferedWriter;
import java.io.ByteArrayInputStream;
import java.io.ByteArrayOutputStream;
import java.io.File;
import java.io.FileOutputStream;
import java.io.FileReader;
import java.io.FileWriter;
import java.io.IOException;
import java.io.ObjectInputStream;
import java.io.ObjectOutputStream;
import java.io.RandomAccessFile;
import java.io.Serializable;
import java.util.Collections;
import java.util.HashMap;
import java.util.Map;
import java.util.Map.Entry;
import java.util.Set;
import java.util.concurrent.atomic.AtomicInteger;
import java.util.concurrent.atomic.AtomicLong;
* 创建时间:2016/6/27
* 编写者:黄伟才
* 功能描述:ASimpleCache是一个为android制定的轻量级的开源缓存框架
* (替换SharePreference当做配置文件)
public class ACache {
public static final int TIME_HOUR = 60 * 60;
public static final int TIME_DAY = TIME_HOUR * 24;
private static final int MAX_SIZE = 1000 * 1000 * 50; // 50 mb
private static final int MAX_COUNT = Integer.MAX_VALUE; // 不限制存放数据的数量
private static Map<String, ACache> mInstanceMap = new HashMap<String, ACache>();
private ACacheManager mCache;
public static ACache get(Context ctx) {
return get(ctx, "ACache");
public static ACache get(Context ctx, String cacheName) {
File f = new File(ctx.getCacheDir(), cacheName);
return get(f, MAX_SIZE, MAX_COUNT);
public static ACache get(File cacheDir) {
return get(cacheDir, MAX_SIZE, MAX_COUNT);
public static ACache get(Context ctx, long max_zise, int max_count) {
File f = new File(ctx.getCacheDir(), "ACache");
return get(f, max_zise, max_count);
public static ACache get(File cacheDir, long max_zise, int max_count) {
ACache manager = mInstanceMap.get(cacheDir.getAbsoluteFile() + myPid());
if (manager == null) {
manager = new ACache(cacheDir, max_zise, max_count);
mInstanceMap.put(cacheDir.getAbsolutePath() + myPid(), manager);
return manager;
private static String myPid() {
return "_" + android.os.Process.myPid();
private ACache(File cacheDir, long max_size, int max_count) {
if (!cacheDir.exists() && !cacheDir.mkdirs()) {
throw new RuntimeException("can't make dirs in "
+ cacheDir.getAbsolutePath());
mCache = new ACacheManager(cacheDir, max_size, max_count);
// ============ String数据 读写 ==============
* 保存 String数据 到 缓存中
* @param key
* 保存的key
* @param value
* 保存的String数据
public void put(String key, String value) {
File file = mCache.newFile(key);
BufferedWriter out = null;
try {
out = new BufferedWriter(new FileWriter(file), 1024);
out.write(value);
} catch (IOException e) {
e.printStackTrace();
} finally {
if (out != null) {
try {
out.flush();
out.close();
mCache.put(file);
