ACache缓存框架工具类(4)
ACache缓存框架工具类(4)
    // ============= 序列化 数据 读写 ===============
     * 保存 Serializable数据 到 缓存中
     * @param key
     *            保存的key
     * @param value
     *            保存的value
    public void put(String key, Serializable value) {
        put(key, value, -1);
     * 保存 Serializable数据到 缓存中
     * @param key
     *            保存的key
     * @param value
     *            保存的value
     * @param saveTime
     *            保存的时间,单位:秒
    public void put(String key, Serializable value, int saveTime) {
        ByteArrayOutputStream baos = null;
        ObjectOutputStream oos = null;
        try {
            baos = new ByteArrayOutputStream();
            oos = new ObjectOutputStream(baos);
            oos.writeObject(value);
            byte[] data = baos.toByteArray();
            if (saveTime != -1) {
                put(key, data, saveTime);
            } else {
                put(key, data);
        } catch (Exception e) {
            e.printStackTrace();
        } finally {
            try {
                oos.close();
            } catch (IOException e) {
     * 读取 Serializable数据
     * @param key
     * @return Serializable 数据
    public Object getAsObject(String key) {
        byte[] data = getAsBinary(key);
        if (data != null) {
            ByteArrayInputStream bais = null;
            ObjectInputStream ois = null;
            try {
                bais = new ByteArrayInputStream(data);
                ois = new ObjectInputStream(bais);
                Object reObject = ois.readObject();
                return reObject;
                return null;
            } finally {
                try {
                    if (bais != null)
                        bais.close();
                try {
                    if (ois != null)
                        ois.close();
        return null;
