EventBus源码分析(2)
EventBus源码分析(2)
继续 register中的方法,for 循环 扫描到的所有方法,然后调用 subscribe
    for (SubscriberMethod subscriberMethod : subscriberMethods) {
          subscribe(subscriber, subscriberMethod, sticky, priority);
    private final Map<Class<?>, CopyOnWriteArrayList<Subscription>> subscriptionsByEventType;
     // Must be called in synchronized block
        private void subscribe(Object subscriber, SubscriberMethod subscriberMethod, boolean sticky, int priority) {
            subscribed = true;
            Class<?> eventType = subscriberMethod.eventType;
            // 根据 subscriberMethod.eventType ,在 subscriptionsByEventType 中查找
            // CopyOnWriteArrayList<Subscription>,如果没有则创建
            // subscriptionsByEventType 是 Map集合,用于存储EventBus所有方法的地方
            // key: eventType,value: CopyOnWriteArrayList<Subscription>
            CopyOnWriteArrayList<Subscription> subscriptions = subscriptionsByEventType.get(eventType);
            // 把 传入的参数封装成 Subscription(subscriber, subscriberMethod, priority) 对象
            Subscription newSubscription = new Subscription(subscriber, subscriberMethod, priority);
            if (subscriptions == null) {
                subscriptions = new CopyOnWriteArrayList<Subscription>();
                subscriptionsByEventType.put(eventType, subscriptions);
            } else {
                for (Subscription subscription : subscriptions) {
                    if (subscription.equals(newSubscription)) {
                        throw new EventBusException("Subscriber " + subscriber.getClass() + " already registered to event "
                                + eventType);
            // Starting with EventBus 2.2 we enforced methods to be public (might change with annotations again)
            // subscriberMethod.method.setAccessible(true);
            int size = subscriptions.size();
            for (int i = 0; i <= size; i++) {
                if (i == size || newSubscription.priority > subscriptions.get(i).priority) {
                    // 添加 newSubscription,优先级高的 添加到 list集合前边
                    subscriptions.add(i, newSubscription);
                    break;
            List<Class<?>> subscribedEvents = typesBySubscriber.get(subscriber);
            if (subscribedEvents == null) {
                subscribedEvents = new ArrayList<Class<?>>();
                typesBySubscriber.put(subscriber, subscribedEvents);
            // 根据  subscriber 存储 所有的 eventType
            // subscribedEvents是 Map 集合,key:subscriber  value: List<eventType>
            subscribedEvents.add(eventType);
            // 判断 sticky:如果为true,从 stickyEvents 中 根据 eventType查找有没有 stickyEvent
            // stickyEvent 就是 post(javabean)中传递的参数,
            // 如果有就调用 postToSubscription,发布
            if (sticky) {
                Object stickyEvent;
                synchronized (stickyEvents) {
                    stickyEvent = stickyEvents.get(eventType);
                if (stickyEvent != null) {
                    // If the subscriber is trying to abort the event, it will fail (event is not tracked in posting state)
                    // --> Strange corner case, which we don't take care of here.
                    postToSubscription(newSubscription, stickyEvent, Looper.getMainLooper() == Looper.myLooper());
