java-怎样在main方法中调用action
java中spring 框架 中的action操作(extends ActionSupport) 一般配置在struts中 通过 浏览器 通过链接形式访问
例如:我的action和配置文件如下:
RapToDpsProjectRaw.java
    package  com.action.rap;
    public class RapToDpsProjectRaw extends ActionSupport {
        private static final long serialVersionUID = 4759438181190004544L;
        private DpsProjectRapReposity dpsProjectRapReposity;
        public void setDpsProjectRapReposity(
                DpsProjectRapReposity dpsProjectRapReposity) {
            this.dpsProjectRapReposity = dpsProjectRapReposity;
        public String execute() {
            System.out.println("已执行");
            return SUCCESS;
rap.xml    spring文件
    <?xml version="1.0" encoding="GBK"?>
    <!-- 指定Spring配置文件的Schema信息 -->
    <beans xmlns="http://www.springframework.org/schema/beans"
        xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="http://www.springframework.org/schema/p"
        xsi:schemaLocation="http://www.springframework.org/schema/beans
        http://www.springframework.org/schema/beans/spring-beans-3.0.xsd">
        <!-- 查询LINKURL -->
        <bean id="rapToDpsProjectRaw" class="com.action.rap.RapToDpsProjectRaw">
            <property name="dpsProjectRapReposity" ref="dpsProjectRapReposity"></property>
        </bean>
    </beans>
rap.xml              struts文件
    <?xml version="1.0" encoding="utf-8"?>
    <!DOCTYPE struts PUBLIC
        "-//Apache Software Foundation//DTD Struts Configuration 2.1.7//EN"
        "http://struts.apache.org/dtds/struts-2.1.7.dtd">
    <struts>
        <package name="rapToDpsProjectRaw" extends="imoen-default" namespace="/rap">
            <action name="rapToDpsProjectRaw" class="rapToDpsProjectRaw">
                <result type="json"></result>
            </action>
        </package>
    </struts>
我要执行这个action  就会在浏览器中输入  http://localhost:8080/项目名/rap/rapToDpsProjectRaw
如果要在 main方式中 运行  主要是获取到 rapToDpsProjectRaw这个Bean  代码如下:
    public static void main(final String[] args) {
            LOG.info("starting to copy record from rap system to mongo db...");
            final String[] paths = new String[] {
                    "resource/spring/action/rap/rap.xml",
                    "resource/struts/rap.xml", "resource/spring/common-beans.xml",
                    "resource/spring/reposity/common-reposity.xml" };
            @SuppressWarnings("resource")
            final ApplicationContext context = new FileSystemXmlApplicationContext(
                    paths); // ClassPathXmlApplicationContext
            final RapToDpsProjectRaw processor = (RapToDpsProjectRaw) context
                    .getBean("rapToDpsProjectRaw");
            final String result = processor.execute();
            if (ActionSupport.SUCCESS.equals(result)) {
                LOG.info("Good job, copy operation succedded!");
            } else {
                LOG.warn("Oops! There's something wrong under the hook!");
            LOG.info("finished copying record from rap system to mongo db.");
