谁有彩灯循环的VHDL程序
计数器加译码器就可以了
这家伙很懒,什么都没有留下。
谁有彩灯循环的VHDL程序
是16个彩灯循环,从左到右逐亮逐灭,从右到左逐亮逐灭,全亮全灭。
如果有的话请发到aweiphysics2000@sina.com 不胜感激~~~~~[em16]
本本
我已经编出来了,谢谢
本本
可以发为我吗,谢谢拉
wetofire@163.com
你可不可以给我看看电路图?
module redlight(clk,reset,out); input clk,reset; output [16:1] out; reg [16:1] out; reg [4:1] counter; always @(posedge clk or posedge reset) if(reset) counter<=0; else begin counter=counter+1; if(counter<18) begin case (counter) 5'd0 : out<=16'h0001; 5'd1 : out<=16'h0002; 5'd2 : out<=16'h0004; 5'd3 : out<=16'h0008; 5'd4 : out<=16'h0010; 5'd5 : out<=16'h0020; 5'd6 : out<=16'h0040; 5'd7 : out<=16'h0080; 5'd8 : out<=16'h0100; 5'd9 : out<=16'h0200; 5'd10: out<=16'h0400; 5'd11: out<=16'h0800; 5'd12: out<=16'h1000; 5'd13: out<=16'h2000; 5'd14: out<=16'h4000; 5'd15: out<=16'h8000; 5'd16: out<=16'hffff; 5'd17: out<=16'h0000; default: out<=16'h0000; endcase end else counter<=5'd0; end endmodule
爱,不是激情的随口
        情,不是瞬间的感动
上面的只是仿真了,下面的是经过测试的。 module redlight(clk,out); input clk; output [16:1] out; reg [16:1] out; reg [5:1] counter; always @(posedge clk ) begin counter=counter+1; if(counter<18) begin case (counter) 5'd0 : out<=16'h0001; 5'd1 : out<=16'h0002; 5'd2 : out<=16'h0004; 5'd3 : out<=16'h0008; 5'd4 : out<=16'h0010; 5'd5 : out<=16'h0020; 5'd6 : out<=16'h0040; 5'd7 : out<=16'h0080; 5'd8 : out<=16'h0100; 5'd9 : out<=16'h0200; 5'd10: out<=16'h0400; 5'd11: out<=16'h0800; 5'd12: out<=16'h1000; 5'd13: out<=16'h2000; 5'd14: out<=16'h4000; 5'd15: out<=16'h8000; 5'd16: out<=16'hffff; 5'd17: out<=16'h0000; default: out<=16'h0000; endcase end else counter<=5'd0; end endmodule
爱,不是激情的随口
        情,不是瞬间的感动
这个是VHDL吗?我怎么看怎么象Verilog呢
www.5iFPGA.com
是VERILOG HDL,因为本人擅长VERILOG HDL就用它编了,哈哈。
爱,不是激情的随口
        情,不是瞬间的感动
呵呵,谢谢斑竹,我也有用
做施耐德电气
斑竹  咱们交流下行吗???  我也是做这个的 我qq   779537131
