M68UICS08+M68EPT08QX
可以到这里提出问题,他们应该很快会回答:
http://www.coelectronic.com.hk/enquiry.html
海纳百川  有容乃大
请参看工具包里的file - Getting_Started_v02_Chinese.pdf 或做以下动作
Connect T2 in M68EPT08Qx to T2 in M68UICS08
- Connect P2 to P5 for QT or P2 to P4 for QL or P2 to P3 QY/QB devices
- Place the MCU to U1 in M68EPT08Qx
- Make sure the J9-J13 in M68UICS08 are default setting as J9(1-2), J10(2-3), J11(1-2), J12(2-3), J13(1-2)
- Make sure J7 is default setting (9.8152MHz) J7(1-2)
- Remove short pin in J4 in M68EPT08Qx (for programming only)
- Connect RS232 cable between J2 in M68UICS08 and PC COM port
- Connect given 9Vdc power to J1 in M68UICS08
- Launch P&E Prog08sz.exe and then set as the Blank device to enter GUI and read the trim value first
(refer to QTQY_PA_User_Guide_v01_Chinese.pdf).
我连好T3准备用MON08烧程序,打开PROG08SZ - Flash Programmer后,SECURITY BYTES没过,下一步该怎么办?T7T8是不用连的哦?黄灯表示什么意思?有SUPPORTER的邮箱么?
---------------------- ----hello world---- ----------------------
1)推荐security bytes 选择“忽略”一项,这样就可以过了
2)单单用CYCLONE MON08烧程序的话,T7T8 不用连。
3)黄灯?是EPT板上的吗?如果是就不用理会。烧程序与它无关。跑DEMO程序时才会起作用
